Dell XPS 14 Fan Replacement
    1. Dell XPS 14 Fan Replacement, Back Panel: step 1, image 1 of 1
      • Position the computer back side up so that the “XPS” logo is facing you.
      • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
      Ask FixBot
    2. Dell XPS 14 Fan Replacement: step 2, image 1 of 3 Dell XPS 14 Fan Replacement: step 2, image 2 of 3 Dell XPS 14 Fan Replacement: step 2, image 3 of 3
      • Use an opening tool to pry up the metal plate.
      • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
      Ask FixBot
    3. Dell XPS 14 Fan Replacement: step 3, image 1 of 2 Dell XPS 14 Fan Replacement: step 3, image 2 of 2
      • Use an opening tool to pop out the back panel.
      • Once unhinged, the panel will open away from you.
      • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
      Ask FixBot
    4. Dell XPS 14 Fan Replacement: step 4, image 1 of 3 Dell XPS 14 Fan Replacement: step 4, image 2 of 3 Dell XPS 14 Fan Replacement: step 4, image 3 of 3
      • Flip over the back panel so that the interior of the panel is facing up.
      • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
      • Remove the black plastic cover that holds the disk in place.
      • Remove the back panel.
      • The GCE disk should still be connected to the computer via a purple ribbon cable.
      Ask FixBot
    1. Dell XPS 14 Fan Replacement, Speaker: step 5, image 1 of 2 Dell XPS 14 Fan Replacement, Speaker: step 5, image 2 of 2
      • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell XPS 14 Fan Replacement: step 6, image 1 of 2 Dell XPS 14 Fan Replacement: step 6, image 2 of 2
      • Remove the speaker from its original location so the wire connector is visible.
      • Unplug the red and white cable plug by pulling out the white end tag.
      • The speaker is now fully removed.
      Ask FixBot
    1. Dell XPS 14 Fan Replacement, Battery: step 7, image 1 of 1
      • Make sure to ground yourself before removing the battery.
      • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
      • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell XPS 14 Fan Replacement: step 8, image 1 of 3 Dell XPS 14 Fan Replacement: step 8, image 2 of 3 Dell XPS 14 Fan Replacement: step 8, image 3 of 3
      • Detach the battery connector from the motherboard using two thumbs to pop it out.
      • Remove the battery from the laptop.
      Ask FixBot
    1. Dell XPS 14 Fan Replacement, Fan: step 9, image 1 of 1
      • Remove the two 2 mm screws from the fan using a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell XPS 14 Fan Replacement: step 10, image 1 of 2 Dell XPS 14 Fan Replacement: step 10, image 2 of 2
      • Use two thumbs to pop out the plug that connects the fan to the laptop.
      • Remove the fan from the laptop.
      Ask FixBot
Gabriella Monico
457 Reputation
5 Guides authored
1 Guide Comment
Thanks for sharing! One question: Isn't it sufficient to just remove the plug of the battery?
Thomas - Reply Share
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 72
All Time: 661
