Dell XPS 1340 CPU Fan Replacement
    1. Dell XPS 1340 CPU Fan Replacement, CPU Fan: step 1, image 1 of 1
      • Remove the battery by sliding the battery lock switch
      Ask FixBot
    2. Dell XPS 1340 CPU Fan Replacement: step 2, image 1 of 1
      • Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
      Ask FixBot
    3. Dell XPS 1340 CPU Fan Replacement: step 3, image 1 of 1
      • Remove two screws which holds a smaller back panel covering only the heatsink
      Ask FixBot
    4. Dell XPS 1340 CPU Fan Replacement: step 4, image 1 of 2 Dell XPS 1340 CPU Fan Replacement: step 4, image 2 of 2
      • Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
      • Now carefully lift the unit from holding the heat pipe.
      • After the heat-pipe unit is removed, the power connector for the fan is accessible.
      Ask FixBot
    5. Dell XPS 1340 CPU Fan Replacement: step 5, image 1 of 2 Dell XPS 1340 CPU Fan Replacement: step 5, image 2 of 2
      • First remove the power connector for the CPU Fan.
      • Now remove the two screws connecting the CPU Fan.
      • Slowly slide the CPU Fan upwards. It would be a little tight around the edges.
      Ask FixBot
    6. Dell XPS 1340 CPU Fan Replacement: step 6, image 1 of 1
      • Unpack the new fan. Make sure the power wires are fixed in the hook provided.
      Ask FixBot
      • Follow all step backwards and finish.
      Ask FixBot
4 other people completed this guide.
Paras Tolani
188 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 109
All Time: 3,359
