Dell XPS 13 Track Pad Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Dell XPS 13 Track Pad Replacement, Back Cover: step 1, image 1 of 2 Dell XPS 13 Track Pad Replacement, Back Cover: step 1, image 2 of 2
      • Remove the eight 4 mm T5 Torx screws from the bottom cover.
      Ask FixBot
    2. Dell XPS 13 Track Pad Replacement: step 2, image 1 of 2 Dell XPS 13 Track Pad Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
      Ask FixBot
    3. Dell XPS 13 Track Pad Replacement: step 3, image 1 of 1
      • Remove the single Phillips screw hidden beneath the flap.
      Ask FixBot
    4. Dell XPS 13 Track Pad Replacement: step 4, image 1 of 1
      • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
      Ask FixBot
    5. Dell XPS 13 Track Pad Replacement: step 5, image 1 of 1
      • Remove the bottom cover.
      Ask FixBot
    1. Dell XPS 13 Track Pad Replacement, Battery Disconnection: step 6, image 1 of 2 Dell XPS 13 Track Pad Replacement, Battery Disconnection: step 6, image 2 of 2
      • Pull the battery cable connector towards the battery to disconnect it from its socket.
      • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
      • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
      • Do not pull up.
      • Open the display and press the power button for five seconds to drain any remaining charge from the system.
      Ask FixBot
    1. Dell XPS 13 Track Pad Replacement, Battery: step 7, image 1 of 2 Dell XPS 13 Track Pad Replacement, Battery: step 7, image 2 of 2
      • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
      Ask FixBot
    2. Dell XPS 13 Track Pad Replacement: step 8, image 1 of 2 Dell XPS 13 Track Pad Replacement: step 8, image 2 of 2
      • Do not pull up.
      Ask FixBot
    3. Dell XPS 13 Track Pad Replacement: step 9, image 1 of 1
      • Peel up any tape securing the speaker cables to the battery.
      • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
      Ask FixBot
    4. Dell XPS 13 Track Pad Replacement: step 10, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. Dell XPS 13 Track Pad Replacement, Track Pad: step 11, image 1 of 2 Dell XPS 13 Track Pad Replacement, Track Pad: step 11, image 2 of 2
      • Remove the four 3 mm Phillips #1 screws from the trackpad.
      Ask FixBot
    2. Dell XPS 13 Track Pad Replacement: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to gently lift the upper-right corner of the track pad.
      • Remove the track pad by slowly pulling it up and away from you.
      Ask FixBot
6 other people completed this guide.
Arvind Krish
215 Reputation
1 Guide authored
Cal Poly, Team S21-G6, Livingston Spring 2017 Member of Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 49
Past 30 Days: 135
All Time: 17,166
