Up to 20% off select tools
Dell XPS 13 Fan Replacement
Views: 30K
View statistics:
Past 24 Hours:
7
Past 7 Days:
43
Past 30 Days:
204
All Time:
29,681
Comments: 36
33 comments on steps, 3 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 8 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the fan in the Dell XPS 13.
    1. Dell XPS 13 Fan Replacement, Back Cover: step 1, image 1 of 2 Dell XPS 13 Fan Replacement, Back Cover: step 1, image 2 of 2
      • Remove the eight 4 mm T5 Torx screws from the bottom cover.
      Ask FixBot
    2. Dell XPS 13 Fan Replacement: step 2, image 1 of 2 Dell XPS 13 Fan Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
      Ask FixBot
    3. Dell XPS 13 Fan Replacement: step 3, image 1 of 1
      • Remove the single Phillips screw hidden beneath the flap.
      Ask FixBot
    4. Dell XPS 13 Fan Replacement: step 4, image 1 of 1
      • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
      Ask FixBot
    5. Dell XPS 13 Fan Replacement: step 5, image 1 of 1
      • Remove the bottom cover.
      Ask FixBot
    1. Dell XPS 13 Fan Replacement, Battery Disconnection: step 6, image 1 of 2 Dell XPS 13 Fan Replacement, Battery Disconnection: step 6, image 2 of 2
      • Pull the battery cable connector towards the battery to disconnect it from its socket.
      • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
      • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
      • Do not pull up.
      • Open the display and press the power button for five seconds to drain any remaining charge from the system.
      Ask FixBot
    1. Dell XPS 13 Fan Replacement, Fan: step 7, image 1 of 3 Dell XPS 13 Fan Replacement, Fan: step 7, image 2 of 3 Dell XPS 13 Fan Replacement, Fan: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the little white connector by pulling it out and away from its socket.
      Ask FixBot
    2. Dell XPS 13 Fan Replacement: step 8, image 1 of 2 Dell XPS 13 Fan Replacement: step 8, image 2 of 2
      • Remove the black standard flat connector by lifting the tab up with your hand.
      Ask FixBot
    3. Dell XPS 13 Fan Replacement: step 9, image 1 of 2 Dell XPS 13 Fan Replacement: step 9, image 2 of 2
      • Remove the 4 mm Phillips #0 screw that connects the fan to the motherboard.
      • Remove the 4 mm Phillips #0 screw that connects the fan to the base of the computer.
      Ask FixBot
    4. Dell XPS 13 Fan Replacement: step 10, image 1 of 2 Dell XPS 13 Fan Replacement: step 10, image 2 of 2
      • Use your right hand to lift up the larger section of the motherboard, closest to the fan.
      • Use your left hand to pull the fan at a 30-degree angle out from underneath the motherboard.
      Ask FixBot
8 other people completed this guide.
Author
with
Ella Herrmann
1,771 Reputation
3 Guides authored
Cal Poly, Team S21-G6, Livingston Spring 2017 Member of Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
5 Members
84 Guides authored
3 Guide Comments
Great guide! The two hardest parts were getting the back cover off, and lifting the motherboard to remove the fan. Took me about 30 minutes in total.
John Reeder - Reply Share
It would be really easier if you remove the battery screws first… there are some steps that were not clear…
Nicolás Jiménez Bautista - Reply Share
This repair took me about 45 min for a complete novice. “Walking out” the battery connector was only way I could unplug it. There was a retaining bracket overlaying the flat connector (step 8) that I needed to unscrew (2 screws, phillips) before it could be removed. Take care to replace the wire in the wire guides along the fan’s housing prior to reinsertion of the replacement fan. It cannot be done afterwards and the back panel will not be flush. Otherwise, this was an excellent guide and an easy repair.
Scott Freeman - Reply Share
Past 24 Hours: 7
Past 7 Days: 43
Past 30 Days: 204
All Time: 29,681
