Dell XPS 13 Battery Replacement
    1. Dell XPS 13 Battery Replacement, Back Cover: step 1, image 1 of 2 Dell XPS 13 Battery Replacement, Back Cover: step 1, image 2 of 2
      • Remove the eight 4 mm T5 Torx screws from the bottom cover.
      Ask FixBot
    2. Dell XPS 13 Battery Replacement: step 2, image 1 of 2 Dell XPS 13 Battery Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
      Ask FixBot
    3. Dell XPS 13 Battery Replacement: step 3, image 1 of 1
      • Remove the single Phillips screw hidden beneath the flap.
      Ask FixBot
    4. Dell XPS 13 Battery Replacement: step 4, image 1 of 1
      • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
      Ask FixBot
    5. Dell XPS 13 Battery Replacement: step 5, image 1 of 1
      • Remove the bottom cover.
      Ask FixBot
    1. Dell XPS 13 Battery Replacement, Battery Disconnection: step 6, image 1 of 2 Dell XPS 13 Battery Replacement, Battery Disconnection: step 6, image 2 of 2
      • Pull the battery cable connector towards the battery to disconnect it from its socket.
      • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
      • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
      • Do not pull up.
      • Open the display and press the power button for five seconds to drain any remaining charge from the system.
      Ask FixBot
    1. Dell XPS 13 Battery Replacement, Battery: step 7, image 1 of 1
      • Remove three Phillips screws labeled "M2x2"
      • Remove a Phillips screw labeled "M1.6x4"
      Ask FixBot
    2. Dell XPS 13 Battery Replacement: step 8, image 1 of 1
      • Peel up any tape securing the speaker cables to the battery.
      • You don't need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
      Ask FixBot
    3. Dell XPS 13 Battery Replacement: step 9, image 1 of 1
      • Remove the battery.
      Ask FixBot
Plug in replacement battery, then plug in the power adaptor, too. If notebook neither charges nor does boot, unplug battery and charger, then remove and re-install coin-cell battery (CMOS, RTC; see Dell’s guide).
282 other people completed this guide.
The Raptor
6,358 Reputation
6 Guides authored
81 Guide Comments
Put compatible batteries under parts.
Keenan Lewis - Reply Share
Awesome instructions. Worked perfectly. I’m back in business now, and it took me about 10 minutes. Thank you so much. By the way, I was using iFixit tools, which really helped. John Day
John Day - Reply Share
using picks to open the case was a little tricky, but without this guide I would have looking for more screws or other ways to open it!
Mark - Reply Share
I followed the instruction carefully and it was quite helpful. However, now that I am done with the battery replacement, the speaker no longer works, and it seems that there is a hardware issue. Any thoughts on this?
Sara Hadavi - Reply Share
@Sara - Looking on another ifixit procedure, I found that the speaker wires are taped to the battery, so I suspect that the speaker was not properly plugged in after reassemble, or that something happened to the wires during battery removal. Hopefully the wires weren’t cut or stretched.
Here is what the XPS 13 teardown procedure had to say:
“….After that, it still isn't a perfectly clean getaway—the speaker wires are strategically taped to the battery in a half dozen spots, which we'll have to liberate to free the battery. (Admittedly, it could have been a lot worse.)
These same wires are trapped under the battery screws—so speaker replacement means battery removal. It looks like the XPS has some layering issues.”
ref: Dell XPS 13 Teardown
I hope this helps.
Graham Vodden - Reply Share
Past 24 Hours: 41
Past 7 Days: 293
Past 30 Days: 1,112
All Time: 392,959
