Dell XPS 13 9370 SSD Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
96
All Time:
550
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
There are several reasons why you may want to exchange the SSD in your Dell XPS 13 9370. The main reason is to have greater storage capacity on your device. Another would be for a failed SSD. By replacing the SSD, you can improve the total storage capacity and even improve loading speeds of the device from using a new drive with faster read and write speeds. Note that after replacing the SSD, you will lose all your data on the device and will have to reinstall Windows.
Tools
    1. Dell XPS 13 9370 SSD Replacement, Back Panel: step 1, image 1 of 2 Dell XPS 13 9370 SSD Replacement, Back Panel: step 1, image 2 of 2
      • Using a Torx #5 screwdriver, remove the eight 3mm screws along the edges of the back panel.
      Ask FixBot
    2. Dell XPS 13 9370 SSD Replacement: step 2, image 1 of 2 Dell XPS 13 9370 SSD Replacement: step 2, image 2 of 2
      • Insert a spudger into the seam between the back panel and the computer frame.
      • Pop the back panel out of place and remove it.
      Ask FixBot
    1. Dell XPS 13 9370 SSD Replacement, SSD: step 3, image 1 of 3 Dell XPS 13 9370 SSD Replacement, SSD: step 3, image 2 of 3 Dell XPS 13 9370 SSD Replacement, SSD: step 3, image 3 of 3
      • Remove the 3.4 mm screw from the SSD cover plate using a Phillips #000 screwdriver.
      • Grab the SSD cover plate and slide it off of the retention post.
      • Remove the SSD cover plate to expose the SSD.
      Ask FixBot
    2. Dell XPS 13 9370 SSD Replacement: step 4, image 1 of 3 Dell XPS 13 9370 SSD Replacement: step 4, image 2 of 3 Dell XPS 13 9370 SSD Replacement: step 4, image 3 of 3
      • The SSD is plugged into the M.2 connector slot.
      • Grab the SSD on both sides and pull it out of the slot.
      Ask FixBot
Caleb Markham
715 Reputation
6 Guides authored
Texas Tech, Team 46-1, Johansen Fall 2025 Member of Texas Tech, Team 46-1, Johansen Fall 2025
TTU-JOHANSEN-F25S46G1
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 96
All Time: 550
