Dell XPS 13 9333 Solid-State Drive Replacement
    1. Dell XPS 13 9333 Solid-State Drive Replacement, Battery: step 1, image 1 of 1
      • Be sure to power off and unplug your device before you begin your repair.
      • Using a Torx T5 screwdriver, remove the ten screws that secure the base cover to the palm-rest assembly.
      • Starting from the back of the computer, pry up the base cover using your fingertips. Then lift the base cover off the palm-rest assembly.
      Ask FixBot
    2. Dell XPS 13 9333 Solid-State Drive Replacement: step 2, image 1 of 1
      • Remove the screw that secures the power-light board to the palm-rest assembly.
      • Unlock the motherboard's power-light socket by lifting the locking latch.
      • Carefully pull the power-light cable's blue tab to slide the cable out of its motherboard socket.
      • Lift and remove the power-light board and cable.
      Ask FixBot
    3. Dell XPS 13 9333 Solid-State Drive Replacement, Disconnecting the Battery Cable: step 3, image 1 of 3 Dell XPS 13 9333 Solid-State Drive Replacement, Disconnecting the Battery Cable: step 3, image 2 of 3 Dell XPS 13 9333 Solid-State Drive Replacement, Disconnecting the Battery Cable: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Carefully pull the battery connector away from the battery to disconnect it from the motherboard. You may find it helpful to insert an iFixit Opening Tool to gently separate the connector from the housing.
      • Pull parallel to the motherboard, not straight up, or you will damage the socket.
      • Use a Phillips screwdriver to remove the eight screws securing the battery.
      • Release the tape underneath the U-shaped hard ribbon connector. There is no need to remove the U-shaped band completely, gently lift the section overhanging the battery and pull back the corners of the tape from the top of the battery upwards. You can use long/fine tweezers to lift the tape completely free of the battery, working from each end.
      • Lift the battery off the palm-rest assembly.
      Ask FixBot
    1. Dell XPS 13 9333 Solid-State Drive Replacement, Solid-State: step 4, image 1 of 1
      • Peel the tape that is adhered over the solid-state drive.
      Ask FixBot
    2. Dell XPS 13 9333 Solid-State Drive Replacement, Remove Old SSD: step 5, image 1 of 1
      • Remove the screw that secures the solid-state drive to the system board.
      • Slide and remove the solid-state drive out of the solid-state drive connector.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
2 other people completed this guide.
Johnathan Hammond
46,185 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,153 Guides authored
3 Guide Comments
Why remove the battery? You can disconnect it and it isn’t blocking access to the ssd.
Bart - Reply Share
what type of SSD is needed ? the Dell M.2 NVMe SSD does not fit!
Karlheinz Salver - Reply Share
disconnecting the battery is necessary (security) ! Then you can change the SSD.
When buying a new SSD for the XPS13-9333 you must buy a "mSATA" and not a NVMe !!
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 43
All Time: 2,799
