Dell XPS 13 9315 Lower Case Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
87
All Time:
252
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this replacement guide to remove the back cover of a Dell XPS 13 9315 laptop. The back cover is the component responsible for protecting the inner components of the laptop that are delicate and prone to direct damage. In this device, the back cover includes 8 back cover Torx screws 3.2 mm by 3.4 mm and 13 retention clips.
Disconnect all external power sources prior to beginning this guide. Make sure to power off your laptop completely before proceeding with any steps involving the inner components of the laptop.
There are no special skills or tools required to complete this guide.
Tools
    1. Dell XPS 13 9315 Lower Case Replacement, Lower Case: step 1, image 1 of 3 Dell XPS 13 9315 Lower Case Replacement, Lower Case: step 1, image 2 of 3 Dell XPS 13 9315 Lower Case Replacement, Lower Case: step 1, image 3 of 3
      • Use a T5 Torx screwdriver to remove the eight 3.2 mm-long screws securing the lower case.
      Ask FixBot
    2. Dell XPS 13 9315 Lower Case Replacement: step 2, image 1 of 3 Dell XPS 13 9315 Lower Case Replacement: step 2, image 2 of 3 Dell XPS 13 9315 Lower Case Replacement: step 2, image 3 of 3
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide the pick around the entire perimeter while prying to disengage the retaining clips.
      Ask FixBot
    3. Dell XPS 13 9315 Lower Case Replacement: step 3, image 1 of 2 Dell XPS 13 9315 Lower Case Replacement: step 3, image 2 of 2
      • The back cover has 13 retention clips attached to the inside of the laptop making it difficult to open the laptop.
      • Make sure that all clips are disengaged, then remove the lower case.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 87
All Time: 252
