Dell XPS 13 9315 Display Assembly Replacement
    1. Dell XPS 13 9315 Display Assembly Replacement, Lower Case: step 1, image 1 of 3 Dell XPS 13 9315 Display Assembly Replacement, Lower Case: step 1, image 2 of 3 Dell XPS 13 9315 Display Assembly Replacement, Lower Case: step 1, image 3 of 3
      • Use a T5 Torx screwdriver to remove the eight 3.2 mm-long screws securing the lower case.
      Ask FixBot
    2. Dell XPS 13 9315 Display Assembly Replacement: step 2, image 1 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 2, image 2 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 2, image 3 of 3
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide the pick around the entire perimeter while prying to disengage the retaining clips.
      Ask FixBot
    3. Dell XPS 13 9315 Display Assembly Replacement: step 3, image 1 of 2 Dell XPS 13 9315 Display Assembly Replacement: step 3, image 2 of 2
      • The back cover has 13 retention clips attached to the inside of the laptop making it difficult to open the laptop.
      • Make sure that all clips are disengaged, then remove the lower case.
      Ask FixBot
    1. Dell XPS 13 9315 Display Assembly Replacement, Dell XPS 13 9315 Battery Disconnection: step 4, image 1 of 1
      • Gently walk the battery connector directly out of its socket.
      Ask FixBot
    1. Dell XPS 13 9315 Display Assembly Replacement, Fan: step 5, image 1 of 3 Dell XPS 13 9315 Display Assembly Replacement, Fan: step 5, image 2 of 3 Dell XPS 13 9315 Display Assembly Replacement, Fan: step 5, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the two screws securing the fan.
      Ask FixBot
    2. Dell XPS 13 9315 Display Assembly Replacement: step 6, image 1 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 6, image 2 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 6, image 3 of 3
      • Flip up the black locking flap securing the fan cable.
      • Disconnect the fan cable.
      Ask FixBot
    3. Dell XPS 13 9315 Display Assembly Replacement: step 7, image 1 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 7, image 2 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 7, image 3 of 3
      • Remove the fan.
      Ask FixBot
    1. Dell XPS 13 9315 Display Assembly Replacement, Display Assembly: step 8, image 1 of 3 Dell XPS 13 9315 Display Assembly Replacement, Display Assembly: step 8, image 2 of 3 Dell XPS 13 9315 Display Assembly Replacement, Display Assembly: step 8, image 3 of 3
      • The back of the laptop after following the prerequisite guides
      • Locate and unscrew the M1.6x3.5 screws on the LCD display connector.
      • Remove the display assembly interposer board from the system board
      Ask FixBot
    2. Dell XPS 13 9315 Display Assembly Replacement: step 9, image 1 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 9, image 2 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 9, image 3 of 3
      • Locate the screws on the hinges on both sides of the laptop for removal.
      • Unscrew the six M2.5x4.3 screws on both sides of the laptop.
      • Unscrew the two M1.6x3 screws on both sides of the laptop.
      • Unscrew the two M1.6x2.5 screws on both sides of the laptop.
      • On both sides of the laptop, firmly grip the highlighted area and pull the hinge up to free the display assembly.
      Ask FixBot
    3. Dell XPS 13 9315 Display Assembly Replacement: step 10, image 1 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 10, image 2 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 10, image 3 of 3
      • Remove the four M1.6x2.3 Phillips screws
      Ask FixBot
    4. Dell XPS 13 9315 Display Assembly Replacement: step 11, image 1 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 11, image 2 of 3 Dell XPS 13 9315 Display Assembly Replacement: step 11, image 3 of 3
      • Pull the back cover away from the display assembly after the removal of the screws
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 43
Past 30 Days: 215
All Time: 867
