Dell XPS 13 7390 Battery Replacement
    1. Dell XPS 13 7390 Battery Replacement, Removing the base cover: step 1, image 1 of 3 Dell XPS 13 7390 Battery Replacement, Removing the base cover: step 1, image 2 of 3 Dell XPS 13 7390 Battery Replacement, Removing the base cover: step 1, image 3 of 3
      • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly
      • With the computer face-down, open the computer at an angle.
      • Using a plastic scribe, pry the base cover from the palm-rest assembly, starting at the front left and right corners.
      • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
      • Lift the base cover from the palm-rest assembly.
      Ask FixBot
    2. Dell XPS 13 7390 Battery Replacement, Remove the old battery: step 2, image 1 of 2 Dell XPS 13 7390 Battery Replacement, Remove the old battery: step 2, image 2 of 2
      • Ensure that the battery cable is disconnected from the system board.
      • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly
      • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
      • Lift the battery off the palm-rest assembly.
      • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
      Ask FixBot
    3. Dell XPS 13 7390 Battery Replacement, Insert the new battery: step 3, image 1 of 1
      • Align the screw holes on the battery with the screw holes on the palm-rest assembly.
      • Replace the four screws (M2x2) that secure the battery to the palm-rest assembly.
      • Replace the screw (M1.6x4) that secures the battery to the palm-rest assembly
      Ask FixBot
    4. Dell XPS 13 7390 Battery Replacement, Reattach base case: step 4, image 1 of 2 Dell XPS 13 7390 Battery Replacement, Reattach base case: step 4, image 2 of 2
      • Align the screw holes on the base cover with the screw holes on the palm-rest assembly and slide in the base cover into place.
      • Replace the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly
      Ask FixBot
Congratulations, you’re all done!
20 other people completed this guide.
Max Kletskov
42,079 Reputation
16 Guides authored
6 Guide Comments
I have an xps 13 7390 and when I perform step 1 - prying open the base cover - the computer turns on. I searched the internet for how to configure my PC to not automatically power on when the lid opens (even when it's only opened 1/4 of the way it tries to turn on) and my BIOS does not seem to have a Power On - Lid Open on/off option. Any suggestions? Thanks.
Uncle - Reply Share
UPDATE - My XPS 7390 does, in fact, have a LID Power on/off option through the F2 Function. This gets you into BIOS and it was all the way at the bottom of the Power Management option. Apologies.
Uncle - Reply Share
This guide is better and more accurate than Dell’s website. Just replaced the battery DHGH8 (4-cell 52 Wh, 7.6 V) in my XPS 7390 with no problems.
Jacob Wickham - Reply Share
I would like to know which battery to use for the 7390 XPS 13 2 in 1?
Hunkel - Reply Share
About as painless as a battery replacement can be. Recommended tools worked very well. Thank you!
nshulga - Reply Share
Past 24 Hours: 12
Past 7 Days: 83
Past 30 Days: 448
All Time: 26,715
