Dell XPS 12 9Q33 mSATA Card Replacement
    1. Dell XPS 12 9Q33 mSATA Card Replacement, Removing the Battery: step 1, image 1 of 1
      • Slide the battery cable connector out of its system board socket.
      • Pull parallel to the motherboard, not straight up, or you will damage the socket.
      • Remove the screws that secure the battery to the palm-rest assembly.
      • Lift and remove the battery along with its cable.
      • Slide and hold the power switch for about five seconds to ground the system board.
      Ask FixBot
    1. Dell XPS 12 9Q33 mSATA Card Replacement, Removing the mSATA card: step 2, image 1 of 1
      • Remove the screw that secures the mSATA card to the system board.
      • Slide and remove the mSATA card out of the mSATA-card connector.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
3 other people completed this guide.
Johnathan Hammond
46,185 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,153 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 607
