Dell XPS 12 9Q23 Touch Pad Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
85
All Time:
2,185
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
For those who wish to swap out the touchpad on their Dell XPS 12 9Q23, this tutorial will lead you through the steps involved. Replacing the touchpad will fix any problems you're having with functionality or responsiveness on your laptop without requiring expert assistance. Before starting any of the steps make sure that the device is powered off before beginning. Make sure you have the necessary equipment before starting, such as a T5 Torx and a Phillips #00 screwdriver, and carefully follow the directions to prevent breaking any parts. You'll have installed and operational new touchpad by the time you finish this guide.
Tools
    1. Dell XPS 12 9Q23 Touch Pad Replacement, Battery: step 1, image 1 of 1
      • Pop the center cover open on the bottom cover.
      • Remove the center screw with a #00 Phillips screwdriver.
      • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
      Ask FixBot
    2. Dell XPS 12 9Q23 Touch Pad Replacement: step 2, image 1 of 1
      • Carefully remove back panel after all screws have been removed.
      Ask FixBot
    3. Dell XPS 12 9Q23 Touch Pad Replacement: step 3, image 1 of 1
      • After the back panel has been removed, disconnect the battery to prevent electrical shock
      Ask FixBot
    4. Dell XPS 12 9Q23 Touch Pad Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
      Ask FixBot
    5. Dell XPS 12 9Q23 Touch Pad Replacement, Remove the battery: step 5, image 1 of 1
      • Once all the screws have been removed the battery is now safe to extract
      Ask FixBot
    1. Dell XPS 12 9Q23 Touch Pad Replacement, Touch Pad: step 6, image 1 of 1
      • Unplug the touchpad cable.
      Ask FixBot
    2. Dell XPS 12 9Q23 Touch Pad Replacement: step 7, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
    3. Dell XPS 12 9Q23 Touch Pad Replacement: step 8, image 1 of 1
      • Use a Phillips screwdriver to remove the 4 touchpad screws.
      Ask FixBot
    4. Dell XPS 12 9Q23 Touch Pad Replacement: step 9, image 1 of 1
      • Remove the touchpad.
      Ask FixBot
You should now have successfully changed the touchpad on your Dell XPS 12 9Q23 after following the instructions in this article. You've fixed your laptop by gently taking off the back panel, unplugging the battery, and replacing the broken touchpad. Make sure to firmly reassemble every part, by following the instructions in reverse order, then double-check your work to make sure nothing is missing. Once your replacement touchpad is placed, your device should be operating at peak efficiency and you can use it without any problems going forward.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 85
All Time: 2,185
