Dell XPS 12 9Q23 Battery Replacement
    1. Dell XPS 12 9Q23 Battery Replacement, Battery: step 1, image 1 of 1
      • Pop the center cover open on the bottom cover.
      • Remove the center screw with a #00 Phillips screwdriver.
      • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
      Ask FixBot
    2. Dell XPS 12 9Q23 Battery Replacement: step 2, image 1 of 1
      • Carefully remove back panel after all screws have been removed.
      Ask FixBot
    3. Dell XPS 12 9Q23 Battery Replacement: step 3, image 1 of 1
      • After the back panel has been removed, disconnect the battery to prevent electrical shock
      Ask FixBot
    4. Dell XPS 12 9Q23 Battery Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
      Ask FixBot
    5. Dell XPS 12 9Q23 Battery Replacement, Remove the battery: step 5, image 1 of 1
      • Once all the screws have been removed the battery is now safe to extract
      Ask FixBot
5 other people completed this guide.
2 Guide Comments
Any tips for registering the new battery in the BIOS?
Ryan Porter - Reply Share
Your battery is automatically recognized.
There is no declaration to be made in the bios.
If the problem persists, I invite you to open a support question:
https://fr.ifixit.com/R%C3%A9ponses/Devi...
Schwarzer - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 113
All Time: 5,400
