Dell XPS 10 USB Port Replacement
    1. Dell XPS 10 USB Port Replacement, Battery: step 1, image 1 of 3 Dell XPS 10 USB Port Replacement, Battery: step 1, image 2 of 3 Dell XPS 10 USB Port Replacement, Battery: step 1, image 3 of 3
      • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
      • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
      • Finally, slide the two plastic opening tools all around the case until it is open.
      Ask FixBot
    2. Dell XPS 10 USB Port Replacement: step 2, image 1 of 3 Dell XPS 10 USB Port Replacement: step 2, image 2 of 3 Dell XPS 10 USB Port Replacement: step 2, image 3 of 3
      • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
      • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
      • Unplug the connector the connects the battery to the mother board.
      • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
      Ask FixBot
    1. Dell XPS 10 USB Port Replacement, USB Port: step 3, image 1 of 3 Dell XPS 10 USB Port Replacement, USB Port: step 3, image 2 of 3 Dell XPS 10 USB Port Replacement, USB Port: step 3, image 3 of 3
      • Use the plastic opening tools to lift up the black cable shown in the picture.
      • Slide one end of the speaker to the other side and the speaker will be out.
      Ask FixBot
    2. Dell XPS 10 USB Port Replacement: step 4, image 1 of 3 Dell XPS 10 USB Port Replacement: step 4, image 2 of 3 Dell XPS 10 USB Port Replacement: step 4, image 3 of 3
      • Unscrew the shown screw in the picture.
      • Remove the silver tape using the plastic tool as shown in the picture.
      • Note: be careful when removing the tape as it is fragile.
      Ask FixBot
    3. Dell XPS 10 USB Port Replacement: step 5, image 1 of 3 Dell XPS 10 USB Port Replacement: step 5, image 2 of 3 Dell XPS 10 USB Port Replacement: step 5, image 3 of 3
      • Unscrew the three screws shown in the picture.
      • 3 mm screws.
      • Slide the small piece shown in green square on both black pieces and lift them up using the plastic tool as shown in the picture.
      • Finally, take the USB port out. You will have three pieces out: the port and the two black pieces as shown in the picture.
      Ask FixBot
James
401 Reputation
3 Guides authored
USF Tampa, Team 2-1, Nance Fall 2016 Member of USF Tampa, Team 2-1, Nance Fall 2016
USFT-NANCE-F16S2G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 41
All Time: 2,317
