Dell Wyse Xn0m Fan Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
82
All Time:
1,763
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If your device feels sluggish/lagging performance-wise over time of use, you might need to change the fan. If these symptoms are followed by overheating easily, the fan being very loud or sounds weird (clicking, clunks, rotational friction), you should definitely do so.
For this teardown, you will need a PH1 Phillips screwdriver and Spudger.
Follow the steps listed to access the fan and then follow back in reverse order to reassemble the laptop one you have replaced the fan with a new one.
Tools
    1. Dell Wyse Xn0m Fan Replacement, Fan: step 1, image 1 of 3 Dell Wyse Xn0m Fan Replacement, Fan: step 1, image 2 of 3 Dell Wyse Xn0m Fan Replacement, Fan: step 1, image 3 of 3
      • Use a spudger to unclip the keyboard from the main body by disengaging the clips lined around the top and sides of the keyboard.
      • Once lifted, push the white slider holding blue ribbon cable and put keyboard to the side.
      Ask FixBot
    2. Dell Wyse Xn0m Fan Replacement: step 2, image 1 of 1
      • With the spudger, remove sliders that are holding the purple ribbon cable.
      • Disconnect cable by the power button.
      Ask FixBot
    3. Dell Wyse Xn0m Fan Replacement: step 3, image 1 of 1
      • Remove the five 7mm Phillips #1 screws underneath the keyboard.
      Ask FixBot
    4. Dell Wyse Xn0m Fan Replacement: step 4, image 1 of 1
      • Close the laptop and flip it over.
      • Remove eight 7mm Phillips #1 screws along the edges of laptop.
      • Put these screws to the side (make sure to keep them apart from keyboard screws).
      Ask FixBot
    5. Dell Wyse Xn0m Fan Replacement: step 5, image 1 of 1
      • After removing the screws, flip the laptop back over and open the screen.
      • Lift the laptop's keyboard/mouse pad top with an opening tool.
      Ask FixBot
    6. Dell Wyse Xn0m Fan Replacement: step 6, image 1 of 2 Dell Wyse Xn0m Fan Replacement: step 6, image 2 of 2
      • Unplug the cable connecting the fan to the motherboard.
      • Lift the tape holding down the cables over the fan.
      • Undo two 5mm Phillips #1 screws.
      • The top left screw is covered by the cables. Use a spudger to get it out of the way.
      • Lift the fan out of its slot.
      Ask FixBot
The process is simple but tedious. Be patient, keep the screws organized, be gentle with the clips and you are good to go!
2 other people completed this guide.
1 Guide Comment
excelent work. thanks for share
Asimple Guy - Reply Share
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 82
All Time: 1,763
