Up to 20% off select tools
Dell Vostro V130 Memory Module Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
59
All Time:
825
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 9 - 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Dell Vostro V130 Memory Module Replacement, Remove the Screws: step 1, image 1 of 1
      • Remove the screws that secure the base cover to the computer.
      Ask FixBot
    2. Dell Vostro V130 Memory Module Replacement, Removing the Base Cover: step 2, image 1 of 1
      • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
    1. Dell Vostro V130 Memory Module Replacement, Disconnecting the Battery: step 3, image 1 of 1
      • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
      Ask FixBot
    2. Dell Vostro V130 Memory Module Replacement, Remove Battery Screws: step 4, image 1 of 1
      • Remove the screws that secure the battery to the computer.
      Ask FixBot
    3. Dell Vostro V130 Memory Module Replacement, Lift the Battery: step 5, image 1 of 1
      • Lift the battery up and away from the computer.
      Ask FixBot
    1. Dell Vostro V130 Memory Module Replacement, LED Cover: step 6, image 1 of 1
      • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
      Ask FixBot
    2. Dell Vostro V130 Memory Module Replacement, Removing the LED Cover: step 7, image 1 of 1
      • Pull the LED cover toward the keyboard and remove it from the computer.
      Ask FixBot
    1. Dell Vostro V130 Memory Module Replacement, Memory Module: step 8, image 1 of 1
      • Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up.
      Ask FixBot
    2. Dell Vostro V130 Memory Module Replacement: step 9, image 1 of 1
      • Remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
      Ask FixBot
Finish Line
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 59
All Time: 825
