Dell Vostro V13 Keyboard Replacement
    1. Dell Vostro V13 Keyboard Replacement, Back Cover: step 1, image 1 of 3 Dell Vostro V13 Keyboard Replacement, Back Cover: step 1, image 2 of 3 Dell Vostro V13 Keyboard Replacement, Back Cover: step 1, image 3 of 3
      • Back up the memory to an external drive and power off the laptop before starting.
      • Flip the laptop over so the vents are facing you.
      • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
      • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
      Ask FixBot
    2. Dell Vostro V13 Keyboard Replacement: step 2, image 1 of 3 Dell Vostro V13 Keyboard Replacement: step 2, image 2 of 3 Dell Vostro V13 Keyboard Replacement: step 2, image 3 of 3
      • Slide out the SD and MicroSD holders.
      • If you are having trouble sliding them out, use the plastic opening tool.
      Ask FixBot
    3. Dell Vostro V13 Keyboard Replacement: step 3, image 1 of 3 Dell Vostro V13 Keyboard Replacement: step 3, image 2 of 3 Dell Vostro V13 Keyboard Replacement: step 3, image 3 of 3
      • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
      • Pull the back cover off.
      Ask FixBot
    4. Dell Vostro V13 Keyboard Replacement: step 4, image 1 of 2 Dell Vostro V13 Keyboard Replacement: step 4, image 2 of 2
      • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
      Ask FixBot
    5. Dell Vostro V13 Keyboard Replacement: step 5, image 1 of 3 Dell Vostro V13 Keyboard Replacement: step 5, image 2 of 3 Dell Vostro V13 Keyboard Replacement: step 5, image 3 of 3
      • Flip up the clip of the ribbon connector.
      • Pull the strip out to disconnect the battery.
      Ask FixBot
    6. Dell Vostro V13 Keyboard Replacement: step 6, image 1 of 2 Dell Vostro V13 Keyboard Replacement: step 6, image 2 of 2
      • Remove the battery.
      • Removing the battery allows you to work safely.
      Ask FixBot
    1. Dell Vostro V13 Keyboard Replacement, Keyboard: step 7, image 1 of 1
      • Open the laptop so the keyboard is visible.
      Ask FixBot
    2. Dell Vostro V13 Keyboard Replacement: step 8, image 1 of 3 Dell Vostro V13 Keyboard Replacement: step 8, image 2 of 3 Dell Vostro V13 Keyboard Replacement: step 8, image 3 of 3
      • Wedge the plastic opening tool around the seam of the notification panel to pop it off.
      Ask FixBot
    3. Dell Vostro V13 Keyboard Replacement: step 9, image 1 of 3 Dell Vostro V13 Keyboard Replacement: step 9, image 2 of 3 Dell Vostro V13 Keyboard Replacement: step 9, image 3 of 3
      • Disconnect the ribbon connector on the panel.
      • Remove the panel.
      Ask FixBot
    4. Dell Vostro V13 Keyboard Replacement: step 10, image 1 of 2 Dell Vostro V13 Keyboard Replacement: step 10, image 2 of 2
      • Remove the two silver 3.1 mm Phillips #1 screws.
      Ask FixBot
    5. Dell Vostro V13 Keyboard Replacement: step 11, image 1 of 2 Dell Vostro V13 Keyboard Replacement: step 11, image 2 of 2
      • Use the plastic opening tool to pry the keyboard out of the laptop.
      • Do not pull the keyboard all the way out yet.
      Ask FixBot
    6. Dell Vostro V13 Keyboard Replacement: step 12, image 1 of 2 Dell Vostro V13 Keyboard Replacement: step 12, image 2 of 2
      • Disconnect the ribbon cable that connects the keyboard to the laptop by flipping up the white locking tab on the ZIF connector.
      • If you're having trouble, use the plastic opening tool to help.
      Ask FixBot
    7. Dell Vostro V13 Keyboard Replacement: step 13, image 1 of 3 Dell Vostro V13 Keyboard Replacement: step 13, image 2 of 3 Dell Vostro V13 Keyboard Replacement: step 13, image 3 of 3
      • Remove the keyboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 68
All Time: 762
