Dell Vostro V13 Disassembly
    1. Dell Vostro V13 Disassembly, Dell Vostro V13 Disassembly: step 1, image 1 of 3 Dell Vostro V13 Disassembly, Dell Vostro V13 Disassembly: step 1, image 2 of 3 Dell Vostro V13 Disassembly, Dell Vostro V13 Disassembly: step 1, image 3 of 3
      • Remove the two plastic dummy cards from the laptop.
      • Unscrew the six PH00 screws from the bottom of the laptop.
      • Unscrew the two PH00 screws from the back of the laptop, located at the extreme left and right of the back panel.
      • Slide the bottom cover forward and lift it upwards to remove.
      • You may need to use a strong spudger to create a gap along the base edge - starting from the Ethernet port on the right toward the Kensington port on the left.
      Ask FixBot
    2. Dell Vostro V13 Disassembly: step 2, image 1 of 1
      • Carefully remove the battery connector. It is a ribbon cable that is clamped down. Flick the black clamp up using the edge nearest the battery. The ribbon cable is now free to move for the next step.
      • Unscrew the four PH00 screws from the battery.
      • Lift the battery upwards to remove it.
      Ask FixBot
    3. Dell Vostro V13 Disassembly: step 3, image 1 of 2 Dell Vostro V13 Disassembly: step 3, image 2 of 2
      • Unscrew the four PH00 screws from the hard drive enclosure.
      • To remove the hard drive, gently lift the drive to a shallow upward angle and carefully slide it to the right.
      • To avoid damaging the SATA port, lift the hard drive to a very small angle while removing it!
      Ask FixBot
    4. Dell Vostro V13 Disassembly: step 4, image 1 of 2 Dell Vostro V13 Disassembly: step 4, image 2 of 2
      • Using a plastic opening tool, pry open the top panel containing the power switch. Start with the bottom-right edge closest to the keyboard.
      • Unclip and remove the ribbon from the panel.
      • Always be careful when removing ribbon cables! Try not to bend them unnecessarily. Do not pull them with excess force.
      Ask FixBot
    5. Dell Vostro V13 Disassembly: step 5, image 1 of 2 Dell Vostro V13 Disassembly: step 5, image 2 of 2
      • Remove the two PH00 screws from the keyboard.
      • Gently lift the keyboard upwards and push it towards the screen to remove.
      • Remove the ribbon cable from underneath the keyboard.
      Ask FixBot
    6. Dell Vostro V13 Disassembly: step 6, image 1 of 2 Dell Vostro V13 Disassembly: step 6, image 2 of 2
      • Remove all of the ribbon cables from the motherboard.
      • Take out the one screw from the audio card and then lift upward to remove.
      Ask FixBot
    7. Dell Vostro V13 Disassembly: step 7, image 1 of 2 Dell Vostro V13 Disassembly: step 7, image 2 of 2
      • Unscrew the six PH00 screws from the memory card reader.
      • Place a hand underneath the memory card reader while unscrewing it so that it doesn't fall out.
      • Remove the CMOS battery cable from the motherboard.
      Ask FixBot
    8. Dell Vostro V13 Disassembly: step 8, image 1 of 1
      • Using a small plastic opening tool, gently lift and remove the two antenna cables from the wireless card.
      • Unscrew the one tiny screw securing the wireless card.
      • The wireless card should pop up.
      • Gently slide the card forward to remove it.
      Ask FixBot
    9. Dell Vostro V13 Disassembly: step 9, image 1 of 2 Dell Vostro V13 Disassembly: step 9, image 2 of 2
      • Remove all six screws from the motherboard.
      • Unscrew the two PH00 screws from the cooling fan.
      • Gently lift the motherboard upward and then slide it forward to remove.
      • Be extremely careful with the motherboard!
      Ask FixBot
    10. Dell Vostro V13 Disassembly: step 10, image 1 of 1
      • Push the two metal clips on either side of the RAM outward; the memory chip will pop up.
      • Pull the memory down from the slot to remove it.
      Ask FixBot
    11. Dell Vostro V13 Disassembly: step 11, image 1 of 1
      • Unscrew the four PH1 screws from the heatsink.
      • You may also need to remove the screw on the fan shroud.
      • Pull the heatsink and the fan upward to remove both.
      Ask FixBot
12 other people completed this guide.
Kevin Dookharan
398 Reputation
1 Guide authored
2 Guide Comments
is the CPU removable?
Trevor Vuong - Reply Share
No, it's not. All laptops have soldered ballpoint CPUs and GPUs.
Chris Yang - Reply Share
Past 24 Hours: 4
Past 7 Days: 43
Past 30 Days: 173
All Time: 39,697
