Up to 20% off select tools
Dell Vostro A840 Memory Module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
48
All Time:
482
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 7 - 15 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Dell Vostro A840 Memory Module Replacement, Remove the battery: step 1, image 1 of 1
      • Unlock the battery by sliding the battery-lock latch towards the outer edge.
      • Slide the battery-bay release latch and hold it.
      • Remove the battery from the battery bay.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
    1. Dell Vostro A840 Memory Module Replacement, Remove the Module Cover: step 2, image 1 of 1
      • Remove the two screws from the module cover.
      • Lift the module cover away from the computer.
      Ask FixBot
    1. Dell Vostro A840 Memory Module Replacement, Removing the Memory Module: step 3, image 1 of 1
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      • Remove the module from the connector.
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 48
All Time: 482
