Up to 20% off select tools
Dell Vostro 5560 Memory Module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
51
All Time:
512
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Dell Vostro 5560 Memory Module Replacement, Removing The Optical-Disk Drive: step 1, image 1 of 1
      • Remove the screw that secures the base cover to the computer.
      • Pull the optical-drive and remove from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
    1. Dell Vostro 5560 Memory Module Replacement, Replacing the Base Cover: step 2, image 1 of 2 Dell Vostro 5560 Memory Module Replacement, Replacing the Base Cover: step 2, image 2 of 2
      • Remove the screws that secure the base cover to the computer.
      • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
      Ask FixBot
    1. Dell Vostro 5560 Memory Module Replacement, Removing the Battery: step 3, image 1 of 1
      • Disconnect the battery cable from its connector on the system board.
      • Lift and remove the battery from the computer.
      Ask FixBot
    1. Dell Vostro 5560 Memory Module Replacement, Removing the Memory Module: step 4, image 1 of 1
      • Pry the securing clips away from the memory module until it pops-up. Remove the memory module from its connector on the system board.
      Ask FixBot
Finish Line
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 51
All Time: 512
