Dell Vostro 5510 Wireless Card Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
71
All Time:
390
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Once you have removed the back cover and gain access to the internal components of the Dell Vostro 15 5510, once of the components you will be able to replace is the fan. To complete this guide, you will need a Phillips #0 screwdriver head and a plastic opening tool. You will not need to do any difficult steps, but take care to disconnect the antenna cables carefully.
Tools
    1. Dell Vostro 5510 Wireless Card Replacement, Back Cover: step 1, image 1 of 1
      • Power off your laptop before beginning disassembly.
      • Place the laptop so the bottom cover is facing upwards.
      Ask FixBot
    2. Dell Vostro 5510 Wireless Card Replacement: step 2, image 1 of 1
      • Remove the remaining (M2x4mm) screws with the screwdriver.
      • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
      Ask FixBot
    3. Dell Vostro 5510 Wireless Card Replacement: step 3, image 1 of 3 Dell Vostro 5510 Wireless Card Replacement: step 3, image 2 of 3 Dell Vostro 5510 Wireless Card Replacement: step 3, image 3 of 3
      • Pry open the top left corner of the cover with the opening tool.
      • Pry open the top right corner of the cover with the opening tool.
      • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
      Ask FixBot
    4. Dell Vostro 5510 Wireless Card Replacement: step 4, image 1 of 3 Dell Vostro 5510 Wireless Card Replacement: step 4, image 2 of 3 Dell Vostro 5510 Wireless Card Replacement: step 4, image 3 of 3
      • Lift the cover to remove it from the rest of the laptop.
      Ask FixBot
    1. Dell Vostro 5510 Wireless Card Replacement, Wireless Card: step 5, image 1 of 1
      • Locate the wireless card.
      Ask FixBot
    2. Dell Vostro 5510 Wireless Card Replacement: step 6, image 1 of 2 Dell Vostro 5510 Wireless Card Replacement: step 6, image 2 of 2
      • Remove the screw (M2x3mm) from the wireless card with the screwdriver.
      • Lift the card without removing it completely.
      Ask FixBot
    3. Dell Vostro 5510 Wireless Card Replacement: step 7, image 1 of 2 Dell Vostro 5510 Wireless Card Replacement: step 7, image 2 of 2
      • Disconnect the antenna cables from the wireless card.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 71
All Time: 390
