Dell Vostro 5510 Touchpad Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
88
All Time:
607
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the touchpad in the Dell Vostro 5510. The touchpad is responsible for moving the mouse and interaction with the screen. Common symptoms of a broken touchpad are inconsistent or erratic responses, no response at all, and not being able to interact with the mouse. Make sure the battery is completely disconnected before starting on the touchpad.
Tools
    1. Dell Vostro 5510 Touchpad Replacement, Back Cover: step 1, image 1 of 1
      • Power off your laptop before beginning disassembly.
      • Place the laptop so the bottom cover is facing upwards.
      Ask FixBot
    2. Dell Vostro 5510 Touchpad Replacement: step 2, image 1 of 1
      • Remove the remaining (M2x4mm) screws with the screwdriver.
      • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
      Ask FixBot
    3. Dell Vostro 5510 Touchpad Replacement: step 3, image 1 of 3 Dell Vostro 5510 Touchpad Replacement: step 3, image 2 of 3 Dell Vostro 5510 Touchpad Replacement: step 3, image 3 of 3
      • Pry open the top left corner of the cover with the opening tool.
      • Pry open the top right corner of the cover with the opening tool.
      • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
      Ask FixBot
    4. Dell Vostro 5510 Touchpad Replacement: step 4, image 1 of 3 Dell Vostro 5510 Touchpad Replacement: step 4, image 2 of 3 Dell Vostro 5510 Touchpad Replacement: step 4, image 3 of 3
      • Lift the cover to remove it from the rest of the laptop.
      Ask FixBot
    1. Dell Vostro 5510 Touchpad Replacement, Battery: step 5, image 1 of 1
      • Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
      Ask FixBot
    2. Dell Vostro 5510 Touchpad Replacement: step 6, image 1 of 3 Dell Vostro 5510 Touchpad Replacement: step 6, image 2 of 3 Dell Vostro 5510 Touchpad Replacement: step 6, image 3 of 3
      • Lift the battery to remove it
      Ask FixBot
    1. Dell Vostro 5510 Touchpad Replacement, Touchpad: step 7, image 1 of 3 Dell Vostro 5510 Touchpad Replacement, Touchpad: step 7, image 2 of 3 Dell Vostro 5510 Touchpad Replacement, Touchpad: step 7, image 3 of 3
      • Disconnect the touchpad from the motherboard using a pair of tweezers.
      • Use a gentle and slow outward movement to minimize the risk of breaking the connection.
      Ask FixBot
    2. Dell Vostro 5510 Touchpad Replacement: step 8, image 1 of 2 Dell Vostro 5510 Touchpad Replacement: step 8, image 2 of 2
      • Remove the three 2.2mm screws holding the guard bar in place with the Phillips #0 screwdriver.
      Ask FixBot
    3. Dell Vostro 5510 Touchpad Replacement: step 9, image 1 of 1
      • Remove the guard bar using a pair of tweezers.
      Ask FixBot
    4. Dell Vostro 5510 Touchpad Replacement: step 10, image 1 of 2 Dell Vostro 5510 Touchpad Replacement: step 10, image 2 of 2
      • Unscrew the two 7 mm base head screws from the touchpad with the Phillips #0 screwdriver.
      Ask FixBot
    5. Dell Vostro 5510 Touchpad Replacement: step 11, image 1 of 1
      • Remove the touchpad from the computer by lifting the side closest to the edge and pulling out.
      Ask FixBot
Emanuel
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 88
All Time: 607
