Dell Vostro 5510 Fan Replacement
    1. Dell Vostro 5510 Fan Replacement, Back Cover: step 1, image 1 of 1
      • Power off your laptop before beginning disassembly.
      • Place the laptop so the bottom cover is facing upwards.
      Ask FixBot
    2. Dell Vostro 5510 Fan Replacement: step 2, image 1 of 1
      • Remove the remaining (M2x4mm) screws with the screwdriver.
      • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
      Ask FixBot
    3. Dell Vostro 5510 Fan Replacement: step 3, image 1 of 3 Dell Vostro 5510 Fan Replacement: step 3, image 2 of 3 Dell Vostro 5510 Fan Replacement: step 3, image 3 of 3
      • Pry open the top left corner of the cover with the opening tool.
      • Pry open the top right corner of the cover with the opening tool.
      • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
      Ask FixBot
    4. Dell Vostro 5510 Fan Replacement: step 4, image 1 of 3 Dell Vostro 5510 Fan Replacement: step 4, image 2 of 3 Dell Vostro 5510 Fan Replacement: step 4, image 3 of 3
      • Lift the cover to remove it from the rest of the laptop.
      Ask FixBot
    1. Dell Vostro 5510 Fan Replacement, Fan: step 5, image 1 of 3 Dell Vostro 5510 Fan Replacement, Fan: step 5, image 2 of 3 Dell Vostro 5510 Fan Replacement, Fan: step 5, image 3 of 3
      • Disconnect the fan cable from the system board.
      Ask FixBot
    2. Dell Vostro 5510 Fan Replacement: step 6, image 1 of 3 Dell Vostro 5510 Fan Replacement: step 6, image 2 of 3 Dell Vostro 5510 Fan Replacement: step 6, image 3 of 3
      • Remove the two (M2x3mm) screws from the fan using the screwdriver.
      Ask FixBot
    3. Dell Vostro 5510 Fan Replacement: step 7, image 1 of 2 Dell Vostro 5510 Fan Replacement: step 7, image 2 of 2
      • Lift the fan to remove it.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 75
All Time: 576
