Dell Vostro 5510 Display Assembly Replacement
    1. Dell Vostro 5510 Display Assembly Replacement, Back Cover: step 1, image 1 of 1
      • Power off your laptop before beginning disassembly.
      • Place the laptop so the bottom cover is facing upwards.
      Ask FixBot
    2. Dell Vostro 5510 Display Assembly Replacement: step 2, image 1 of 1
      • Remove the remaining (M2x4mm) screws with the screwdriver.
      • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
      Ask FixBot
    3. Dell Vostro 5510 Display Assembly Replacement: step 3, image 1 of 3 Dell Vostro 5510 Display Assembly Replacement: step 3, image 2 of 3 Dell Vostro 5510 Display Assembly Replacement: step 3, image 3 of 3
      • Pry open the top left corner of the cover with the opening tool.
      • Pry open the top right corner of the cover with the opening tool.
      • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
      Ask FixBot
    4. Dell Vostro 5510 Display Assembly Replacement: step 4, image 1 of 3 Dell Vostro 5510 Display Assembly Replacement: step 4, image 2 of 3 Dell Vostro 5510 Display Assembly Replacement: step 4, image 3 of 3
      • Lift the cover to remove it from the rest of the laptop.
      Ask FixBot
    1. Dell Vostro 5510 Display Assembly Replacement, Display Assembly: step 5, image 1 of 3 Dell Vostro 5510 Display Assembly Replacement, Display Assembly: step 5, image 2 of 3 Dell Vostro 5510 Display Assembly Replacement, Display Assembly: step 5, image 3 of 3
      • Remove the six 4 mm hinge screws using the Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Vostro 5510 Display Assembly Replacement: step 6, image 1 of 2 Dell Vostro 5510 Display Assembly Replacement: step 6, image 2 of 2
      • Flip up the hinge panel for the left side of the laptop.
      • Flip up the hinge panel for the right side of the laptop.
      Ask FixBot
    3. Dell Vostro 5510 Display Assembly Replacement: step 7, image 1 of 2 Dell Vostro 5510 Display Assembly Replacement: step 7, image 2 of 2
      • Disconnect the display cable with your hands.
      Ask FixBot
    4. Dell Vostro 5510 Display Assembly Replacement: step 8, image 1 of 1
      • Lift up the laptop with your hands to detach it from the display assembly.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 76
All Time: 675
