Dell Vostro 5510 Back Cover Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
78
All Time:
912
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The first step in any replacement of the internal components of the Dell Vostro 15 5510 is to remove its back cover. To complete this guide, you will need a Phillips #0 screwdriver head and a plastic opening tool. This guide also is necessary for accessing most of the internal components of the laptop.
Tools
    1. Dell Vostro 5510 Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Power off your laptop before beginning disassembly.
      • Place the laptop so the bottom cover is facing upwards.
      Ask FixBot
    2. Dell Vostro 5510 Back Cover Replacement: step 2, image 1 of 1
      • Remove the remaining (M2x4mm) screws with the screwdriver.
      • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
      Ask FixBot
    3. Dell Vostro 5510 Back Cover Replacement: step 3, image 1 of 3 Dell Vostro 5510 Back Cover Replacement: step 3, image 2 of 3 Dell Vostro 5510 Back Cover Replacement: step 3, image 3 of 3
      • Pry open the top left corner of the cover with the opening tool.
      • Pry open the top right corner of the cover with the opening tool.
      • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
      Ask FixBot
    4. Dell Vostro 5510 Back Cover Replacement: step 4, image 1 of 3 Dell Vostro 5510 Back Cover Replacement: step 4, image 2 of 3 Dell Vostro 5510 Back Cover Replacement: step 4, image 3 of 3
      • Lift the cover to remove it from the rest of the laptop.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 78
All Time: 912
