Up to 20% off select tools
Dell Vostro 5470 Memory Module Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
53
All Time:
1,510
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Dell Vostro 5470 Memory Module Replacement, Remove the Screws: step 1, image 1 of 1
      • Remove the screws that secure the base cover to the computer.
      Ask FixBot
    2. Dell Vostro 5470 Memory Module Replacement, Loosening the Base Cover: step 2, image 1 of 1
      • Pry the base cover along the edges to loosen it.
      Ask FixBot
    3. Dell Vostro 5470 Memory Module Replacement, Removing the Base Cover: step 3, image 1 of 1
      • Lift and remove the base cover from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
    1. Dell Vostro 5470 Memory Module Replacement, Disconnecting the Battery Cable: step 4, image 1 of 1
      • Disconnect the battery cable from its connector on the system board.
      Ask FixBot
    2. Dell Vostro 5470 Memory Module Replacement, Releasing the Tabs: step 5, image 1 of 1
      • Release the tabs that secure the battery in the battery bay.
      Ask FixBot
    3. Dell Vostro 5470 Memory Module Replacement, Removing the Battery: step 6, image 1 of 1
      • Lift and remove the battery from the computer.
      Ask FixBot
    1. Dell Vostro 5470 Memory Module Replacement, Memory Module: step 7, image 1 of 1
      • Pry the securing clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 53
All Time: 1,510
