Up to 20% off select tools
Dell Vostro 5459 Memory Module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
59
All Time:
697
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 9 - 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Dell Vostro 5459 Memory Module Replacement, Removing the Base Cover: step 1, image 1 of 1
      • Remove the screws that secure the back cover to the computer.
      • Pry the edges of the back cover from all sides, to release the back cover.
      • Lift the back cover from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
    1. Dell Vostro 5459 Memory Module Replacement, Removing the Battery: step 2, image 1 of 1
      • Disconnect the battery cable from the connector on the system board [1].
      • Remove the screws that secure the battery to the computer [2].
      • Lift and remove the battery from the computer [3].
      Ask FixBot
    1. Dell Vostro 5459 Memory Module Replacement, Removing the Memory Module: step 3, image 1 of 1
      • Lift the plastic enclosure covering the top of the memory module compartment.
      • Pull the retention clips from the memory module until it pops up.
      • Remove the memory module from the connector on the system board.
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 59
All Time: 697
