Up to 20% off select tools
Dell Vostro 3561 Memory Module Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
53
All Time:
1,099
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 - 15 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will show you how to remove and replace the Memory Module.
    1. Dell Vostro 3561 Memory Module Replacement, Sliding the Battery Release Latch: step 1, image 1 of 1
      • Flip the computer over.
      • Slide the battery release latch to the unlock position.
      Ask FixBot
    2. Dell Vostro 3561 Memory Module Replacement, Slide the Battery Release Latch: step 2, image 1 of 1
      • Slide the other battery release latch to the unlock position.
      Ask FixBot
    3. Dell Vostro 3561 Memory Module Replacement, Removing the Battery: step 3, image 1 of 1
      • Slide the battery and remove it from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
    1. Dell Vostro 3561 Memory Module Replacement, Remove the Screws: step 4, image 1 of 1
      • Remove the screws that secure the base cover to the computer.
      Ask FixBot
    2. Dell Vostro 3561 Memory Module Replacement, Removing the Base Cover: step 5, image 1 of 1
      • Lift up the base cover and remove it from the computer.
      Ask FixBot
    1. Dell Vostro 3561 Memory Module Replacement, Releasing the Memory Module: step 6, image 1 of 1
      • Push apart the memory retention clips to release the memory module.
      Ask FixBot
    2. Dell Vostro 3561 Memory Module Replacement, Removing the Memory Module: step 7, image 1 of 1
      • Remove the memory module from its connector on the system board.
      Ask FixBot
Finish Line
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 53
All Time: 1,099
