Up to 20% off select tools
Dell Vostro 3560 RAM Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
67
All Time:
1,259
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the RAM in your Dell Vostro 3560 laptop. Some parts of this guide was made with info from this video.
    1. Dell Vostro 3560 RAM Replacement, Identify your laptop: step 1, image 1 of 2 Dell Vostro 3560 RAM Replacement, Identify your laptop: step 1, image 2 of 2
      • Make sure you have the right laptop by checking the sticker.
      Ask FixBot
    2. Dell Vostro 3560 RAM Replacement, Remove Battery: step 2, image 1 of 2 Dell Vostro 3560 RAM Replacement, Remove Battery: step 2, image 2 of 2
      • Start with your PC shut off and upside down.
      • Pull out tabs.
      • Pull up on rail to remove battery.
      Ask FixBot
    1. Dell Vostro 3560 RAM Replacement, Remove Back Panel: step 3, image 1 of 1
      • Remove the two screws:
      • One M2 Phillips screw (Fixed)
      • One 5-mm M2 Phillips screw
      Ask FixBot
    2. Dell Vostro 3560 RAM Replacement: step 4, image 1 of 3 Dell Vostro 3560 RAM Replacement: step 4, image 2 of 3 Dell Vostro 3560 RAM Replacement: step 4, image 3 of 3
      • Use a iFixit opening tool to remove the back panel.
      Ask FixBot
    3. Dell Vostro 3560 RAM Replacement: step 5, image 1 of 1
      • From here you can access:
      • The hard drive
      • The RAM.
      • The CD Drive.
      Ask FixBot
    1. Dell Vostro 3560 RAM Replacement, RAM Removal: step 6, image 1 of 1
      • We will focus on the RAM.
      Ask FixBot
    2. Dell Vostro 3560 RAM Replacement: step 7, image 1 of 3 Dell Vostro 3560 RAM Replacement: step 7, image 2 of 3 Dell Vostro 3560 RAM Replacement: step 7, image 3 of 3
      • Pull out on the tabs to release RAM.
      • Pull out the RAM.
      • If you have two SoDIMMs installed, start with the top one and repeat the proccess for the lower one.
      • When reinstalling ram, make sure it is fully inserted before fully locking it down.
      Ask FixBot
Author
with
Max Bareilles
703 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 67
All Time: 1,259
