Dell Vostro 3560 Optical Drive Replacement
    1. Dell Vostro 3560 Optical Drive Replacement, Identify your laptop: step 1, image 1 of 2 Dell Vostro 3560 Optical Drive Replacement, Identify your laptop: step 1, image 2 of 2
      • Make sure you have the right laptop by checking the sticker.
      Ask FixBot
    2. Dell Vostro 3560 Optical Drive Replacement, Remove Battery: step 2, image 1 of 2 Dell Vostro 3560 Optical Drive Replacement, Remove Battery: step 2, image 2 of 2
      • Start with your PC shut off and upside down.
      • Pull out tabs.
      • Pull up on rail to remove battery.
      Ask FixBot
    1. Dell Vostro 3560 Optical Drive Replacement, Remove Back Panel: step 3, image 1 of 1
      • Remove the two screws:
      • One M2 Phillips screw (Fixed)
      • One 5-mm M2 Phillips screw
      Ask FixBot
    2. Dell Vostro 3560 Optical Drive Replacement: step 4, image 1 of 3 Dell Vostro 3560 Optical Drive Replacement: step 4, image 2 of 3 Dell Vostro 3560 Optical Drive Replacement: step 4, image 3 of 3
      • Use a iFixit opening tool to remove the back panel.
      Ask FixBot
    3. Dell Vostro 3560 Optical Drive Replacement: step 5, image 1 of 1
      • From here you can access:
      • The hard drive
      • The RAM.
      • The CD Drive.
      Ask FixBot
    1. Dell Vostro 3560 Optical Drive Replacement, Optical Drive: step 6, image 1 of 1
      • We will focus on the Optical Drive.
      Ask FixBot
    2. Dell Vostro 3560 Optical Drive Replacement, Remove Optical Drive: step 7, image 1 of 1
      • Remove the 3-mm M2 Phillips screws.
      Ask FixBot
    3. Dell Vostro 3560 Optical Drive Replacement: step 8, image 1 of 3 Dell Vostro 3560 Optical Drive Replacement: step 8, image 2 of 3 Dell Vostro 3560 Optical Drive Replacement: step 8, image 3 of 3
      • Pull the optical drive out of the frame.
      • If it doesn't come out immediately, you might have to shake it.
      Ask FixBot
Max Bareilles
703 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 73
All Time: 722
