Up to 20% off select tools
Dell Vostro 3559 Memory Module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
52
All Time:
477
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 7 - 15 minutes
Difficulty: Very easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Module.
    1. Dell Vostro 3559 Memory Module Replacement, Sliding the Latch: step 1, image 1 of 1
      • Slide the release latch outwards to unlock the battery.
      Ask FixBot
    2. Dell Vostro 3559 Memory Module Replacement, Remove the Battery: step 2, image 1 of 1
      • Remove the battery from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
    1. Dell Vostro 3559 Memory Module Replacement, Remove the Screws: step 3, image 1 of 1
      • Remove the screws that secure the access panel to the computer.
      • Lift the access panel partially at a 45–degree angle.
      Ask FixBot
    2. Dell Vostro 3559 Memory Module Replacement, Remove the Access Panel: step 4, image 1 of 1
      • Remove the access panel from the computer.
      Ask FixBot
    1. Dell Vostro 3559 Memory Module Replacement, Removing the Memory Module: step 5, image 1 of 1
      • Pry the securing clips away from the memory module until it pops up.
      • Remove the memory module from its socket on the system board.
      Ask FixBot
Finish Line
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 52
All Time: 477
