Up to 20% off select tools
Dell Vostro 3555 Memory Module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
52
All Time:
451
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 - 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Dell Vostro 3555 Memory Module Replacement, Unlocking the Battery: step 1, image 1 of 1
      • Slide the release latches to unlock the battery.
      Ask FixBot
    2. Dell Vostro 3555 Memory Module Replacement, Removing the Battery: step 2, image 1 of 1
      • Slide the battery and remove it from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
    1. Dell Vostro 3555 Memory Module Replacement, Remove the Screws: step 3, image 1 of 1
      • Remove the screws that secure the access panel to the base of the computer.
      Ask FixBot
    2. Dell Vostro 3555 Memory Module Replacement, Lifting the Access Panel: step 4, image 1 of 1
      • Lift the access panel up at an angle and remove it from the computer.
      Ask FixBot
    1. Dell Vostro 3555 Memory Module Replacement, Memory Module: step 5, image 1 of 1
      • Pry the retention clips away from the memory module until it pops up.
      Ask FixBot
    2. Dell Vostro 3555 Memory Module Replacement: step 6, image 1 of 1
      • Remove the memory module from its connector on the system board.
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 52
All Time: 451
