Dell Vostro 3550 RAM Replacement
    1. Dell Vostro 3550 RAM Replacement, Unlocking the Battery: step 1, image 1 of 1
      • Slide the release latches to unlock the battery.
      Ask FixBot
    2. Dell Vostro 3550 RAM Replacement, Sliding the Battery: step 2, image 1 of 1
      • Slide the battery and remove it from the computer.
      Ask FixBot
    1. Dell Vostro 3550 RAM Replacement, Remove the Screws: step 3, image 1 of 1
      • Remove the three 7mm Phillips #0 screws that secure the access panel to the base of the computer.
      Ask FixBot
    2. Dell Vostro 3550 RAM Replacement, Lifting the Access Panel: step 4, image 1 of 1
      • Lift the access panel up at an angle and remove it from the computer.
      Ask FixBot
    1. Dell Vostro 3550 RAM Replacement, RAM: step 5, image 1 of 3 Dell Vostro 3550 RAM Replacement, RAM: step 5, image 2 of 3 Dell Vostro 3550 RAM Replacement, RAM: step 5, image 3 of 3
      • Push outward on the two release tabs securing either side of the top RAM module.
      Ask FixBot
    2. Dell Vostro 3550 RAM Replacement: step 6, image 1 of 3 Dell Vostro 3550 RAM Replacement: step 6, image 2 of 3 Dell Vostro 3550 RAM Replacement: step 6, image 3 of 3
      • Lift the top stick of RAM upward away from the motherboard.
      Ask FixBot
    3. Dell Vostro 3550 RAM Replacement: step 7, image 1 of 2 Dell Vostro 3550 RAM Replacement: step 7, image 2 of 2
      • Push outward on the two release tabs securing either side of the second RAM module.
      Ask FixBot
    4. Dell Vostro 3550 RAM Replacement: step 8, image 1 of 3 Dell Vostro 3550 RAM Replacement: step 8, image 2 of 3 Dell Vostro 3550 RAM Replacement: step 8, image 3 of 3
      • Lift the stick of RAM upward away from the motherboard.
      Ask FixBot
Nickolas LaForce
178 Reputation
1 Guide authored
1 Guide Comment
Hi
Thanks for the tutorial.
High standard.
Keep it up
Regards
Lourens
Lourens - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 61
All Time: 1,026
