Dell Vostro 3550 Display Assembly Replacement
    1. Dell Vostro 3550 Display Assembly Replacement, Display Assembly: step 1, image 1 of 2 Dell Vostro 3550 Display Assembly Replacement, Display Assembly: step 1, image 2 of 2
      • Grip the back trim of the laptop and pull upwards to remove it.
      Ask FixBot
    2. Dell Vostro 3550 Display Assembly Replacement: step 2, image 1 of 3 Dell Vostro 3550 Display Assembly Replacement: step 2, image 2 of 3 Dell Vostro 3550 Display Assembly Replacement: step 2, image 3 of 3
      • Slide the plastic opening tool around the perimeter of the display bezel.
      • Carefully remove the bezel from the display.
      Ask FixBot
    3. Dell Vostro 3550 Display Assembly Replacement: step 3, image 1 of 3 Dell Vostro 3550 Display Assembly Replacement: step 3, image 2 of 3 Dell Vostro 3550 Display Assembly Replacement: step 3, image 3 of 3
      • Remove the six 7 mm Phillips #0 screws attaching the display to the upper casing of the laptop.
      • When all six screws are removed, gently lower the display to reveal the camera cable.
      Ask FixBot
    4. Dell Vostro 3550 Display Assembly Replacement: step 4, image 1 of 3 Dell Vostro 3550 Display Assembly Replacement: step 4, image 2 of 3 Dell Vostro 3550 Display Assembly Replacement: step 4, image 3 of 3
      • Disconnect the camera ribbon cable by gently pulling it away from its connector.
      Ask FixBot
    5. Dell Vostro 3550 Display Assembly Replacement: step 5, image 1 of 2 Dell Vostro 3550 Display Assembly Replacement: step 5, image 2 of 2
      • Remove the four 5 mm Phillips #0 screws (two on either side) securing the display to the metal frame.
      Ask FixBot
    6. Dell Vostro 3550 Display Assembly Replacement: step 6, image 1 of 3 Dell Vostro 3550 Display Assembly Replacement: step 6, image 2 of 3 Dell Vostro 3550 Display Assembly Replacement: step 6, image 3 of 3
      • Gently lower the display into a resting position.
      Ask FixBot
    7. Dell Vostro 3550 Display Assembly Replacement: step 7, image 1 of 3 Dell Vostro 3550 Display Assembly Replacement: step 7, image 2 of 3 Dell Vostro 3550 Display Assembly Replacement: step 7, image 3 of 3
      • Loosen the clear tape fastening the ribbon cable to the display.
      • Carefully pull the ribbon cable away from the connector.
      Ask FixBot
    8. Dell Vostro 3550 Display Assembly Replacement: step 8, image 1 of 3 Dell Vostro 3550 Display Assembly Replacement: step 8, image 2 of 3 Dell Vostro 3550 Display Assembly Replacement: step 8, image 3 of 3
      • Peel the ribbon cable away from the display.
      • Remove the display from the laptop.
      Ask FixBot
Dylan J. Souza
781 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 67
All Time: 1,194
