Dell Vostro 3510 Battery Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
25
Past 30 Days:
108
All Time:
883
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide is a battery replacement for the Dell Vostro 3510.
Parts
Tools
    1. Dell Vostro 3510 Battery Replacement, Battery: step 1, image 1 of 2 Dell Vostro 3510 Battery Replacement, Battery: step 1, image 2 of 2
      • Ensure the laptop is powered off.
      • Flip the laptop over.
      Ask FixBot
    2. Dell Vostro 3510 Battery Replacement: step 2, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips #0 screwdriver to remove the screws highlighted with red circles.
      • Loosen the two 1 mm captive screws (orange circles in the image) on the back corners of the bottom cover.
      • Keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
      Ask FixBot
    3. Dell Vostro 3510 Battery Replacement: step 3, image 1 of 2 Dell Vostro 3510 Battery Replacement: step 3, image 2 of 2
      • Open up the back cover of the laptop.
      • It is much easier to open up the laptop with any type of spudger or with Jimmy.
      Ask FixBot
    4. Dell Vostro 3510 Battery Replacement: step 4, image 1 of 2 Dell Vostro 3510 Battery Replacement: step 4, image 2 of 2
      • Remove the battery cable from the motherboard by lightly pulling on the black tape attached to the ribbon cable.
      Ask FixBot
    5. Dell Vostro 3510 Battery Replacement: step 5, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the three battery screws.
      • Carefully move the additional sata storage ribbon cable to the side.
      Ask FixBot
    6. Dell Vostro 3510 Battery Replacement: step 6, image 1 of 1
      • Gently remove the battery from the laptop.
      • Be careful with the other ribbon cables.
      Ask FixBot
2 other people completed this guide.
Jhoan Cruz
517 Reputation
3 Guides authored
Gateway, Team 16-1, Gonzalez Spring 2024 Member of Gateway, Team 16-1, Gonzalez Spring 2024
GCC-GONZALEZ-S24S16G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 25
Past 30 Days: 108
All Time: 883
