Up to 20% off select tools
Dell Vostro 3500 Memory Module Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
67
All Time:
1,207
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 7 - 15 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Module.
    1. Dell Vostro 3500 Memory Module Replacement, Sliding the Battery Latch: step 1, image 1 of 1
      • Flip the computer over.
      • Slide the battery release latch to the unlock position.
      Ask FixBot
    2. Dell Vostro 3500 Memory Module Replacement, Sliding the Battery Release Latch: step 2, image 1 of 1
      • Slide the other battery release latch to the unlock position.
      Ask FixBot
    3. Dell Vostro 3500 Memory Module Replacement, Removing the Battery: step 3, image 1 of 1
      • Slide the battery and remove it from the computer.
      Ask FixBot
    1. Dell Vostro 3500 Memory Module Replacement, Remove the Screws: step 4, image 1 of 1
      • Turn the laptop over and remove two screws securing the service cover.
      Ask FixBot
    2. Dell Vostro 3500 Memory Module Replacement, Removing the Base Cover: step 5, image 1 of 1
      • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
      • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
      Ask FixBot
    1. Dell Vostro 3500 Memory Module Replacement, Releasing the Memory Module: step 6, image 1 of 1
      • Push apart the memory retention clips to release the memory module.
      Ask FixBot
    2. Dell Vostro 3500 Memory Module Replacement, Remove the Memory Module: step 7, image 1 of 1
      • Remove the memory module from its connector on the system board.
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 67
All Time: 1,207
