Dell Vostro 3500 CMOS Battery Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
Past 7 Days:
28
Past 30 Days:
103
All Time:
3,533
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Note that disconnecting the so-called CMOS battery does not reset the BIOS settings or clear a BIOS password. In fact its only purpose is to maintain the real time clock when no other power source is available.
The CMOS battery should last for around 10 years. If the computer forgets the date and time when you remove both the mains adapter and the main battery then you need to replace the CMOS battery.
Tools
    1. Dell Vostro 3500 CMOS Battery Replacement, Sliding the Battery Latch: step 1, image 1 of 1
      • Flip the computer over.
      • Slide the battery release latch to the unlock position.
      Ask FixBot
    2. Dell Vostro 3500 CMOS Battery Replacement, Sliding the Battery Release Latch: step 2, image 1 of 1
      • Slide the other battery release latch to the unlock position.
      Ask FixBot
    3. Dell Vostro 3500 CMOS Battery Replacement, Removing the Battery: step 3, image 1 of 1
      • Slide the battery and remove it from the computer.
      Ask FixBot
    1. Dell Vostro 3500 CMOS Battery Replacement, Remove the Screws: step 4, image 1 of 1
      • Turn the laptop over and remove two screws securing the service cover.
      Ask FixBot
    2. Dell Vostro 3500 CMOS Battery Replacement, Removing the Base Cover: step 5, image 1 of 1
      • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
      • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
      Ask FixBot
    1. Dell Vostro 3500 CMOS Battery Replacement, CMOS battery removal: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Locate the CMOS battery
      • Gently disengage its connector.
      • Do not disengage the connector by pulling the leads as you may tear them out of the connector. Instead, pull on the connector itself, ideally with a pair of tweezers, rocking it back and forth alternately in the directions of the red and black leads.
      Ask FixBot
Philip Le Riche
32,691 Reputation
48 Guides authored
Restart Project Member of Restart Project
Local Repair Groups
33 Members
2,400 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 28
Past 30 Days: 103
All Time: 3,533
