Dell Vostro 3450 Palm Rest Replacement
    1. Dell Vostro 3450 Palm Rest Replacement, Unlocking the Battery: step 1, image 1 of 1
      • Slide the left and the right battery release latches to the unlock position.
      Ask FixBot
    2. Dell Vostro 3450 Palm Rest Replacement, Removing the Battery: step 2, image 1 of 1
      • Slide the battery and remove it from the computer.
      Ask FixBot
    1. Dell Vostro 3450 Palm Rest Replacement, Loosen the Screw: step 3, image 1 of 1
      • Loosen the screw that secures the memory door.
      Ask FixBot
    2. Dell Vostro 3450 Palm Rest Replacement, Removing the Memory Door: step 4, image 1 of 1
      • Pry up the memory door near the screw hole, lift and remove it.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
    1. Dell Vostro 3450 Palm Rest Replacement, Remove the Screw: step 5, image 1 of 1
      • Remove the screw that secures the optical drive to the computer.
      Ask FixBot
    2. Dell Vostro 3450 Palm Rest Replacement, Prying the Drive: step 6, image 1 of 1
      • Gently pry the optical drive out of the computer.
      Ask FixBot
    3. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: step 7, image 1 of 1
      • Remove the screws that secure the optical drive bracket.
      Ask FixBot
    4. Dell Vostro 3450 Palm Rest Replacement, Removing the Optical Drive: step 8, image 1 of 1
      • Remove the optical drive bracket from the optical drive module.
      Ask FixBot
    1. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: step 9, image 1 of 1
      • Remove the screws in the battery compartment.
      Ask FixBot
    2. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: step 10, image 1 of 1
      • Remove the screws in the optical drive compartment.
      Ask FixBot
    3. Dell Vostro 3450 Palm Rest Replacement, Remove the Rubber: step 11, image 1 of 1
      • Remove the rubber from the bottom base on the right side.
      Ask FixBot
    4. Dell Vostro 3450 Palm Rest Replacement, Remove the Rubber: step 12, image 1 of 1
      • Remove the rubber from the bottom base on the left side.
      Ask FixBot
    5. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: step 13, image 1 of 1
      • Remove all the screws from the bottom base.
      Ask FixBot
    6. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: step 14, image 1 of 1
      • Flip the computer around and remove the screws that secures the palm rest.
      Ask FixBot
    7. Dell Vostro 3450 Palm Rest Replacement, Release the Latches: step 15, image 1 of 1
      • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
      Ask FixBot
    8. Dell Vostro 3450 Palm Rest Replacement, Release the Latch: step 16, image 1 of 1
      • Release the latch on the system board connector and then disconnect the power button cable.
      Ask FixBot
    9. Dell Vostro 3450 Palm Rest Replacement, Disconnecting the Key Cable: step 17, image 1 of 1
      • Release the latch on the system board connector and then disconnect the hot key cable.
      Ask FixBot
    10. Dell Vostro 3450 Palm Rest Replacement, Prying the Palm Rest: step 18, image 1 of 1
      • Pry up the right side of the palm rest.
      Ask FixBot
    11. Dell Vostro 3450 Palm Rest Replacement, Prying the Palm Rest: step 19, image 1 of 1
      • Pry up the left side of the palm rest.
      Ask FixBot
    12. Dell Vostro 3450 Palm Rest Replacement, Prying the Sides: step 20, image 1 of 1
      • Pry up the sides of the palm rest and remove it from the computer.
      Ask FixBot
Finish Line
Johnathan Hammond
46,185 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,136 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 516
