Up to 20% off select tools
Dell Vostro 3450 Memory Module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
59
All Time:
855
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 - 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will show you how to remove and replace the Memory Module.
    1. Dell Vostro 3450 Memory Module Replacement, Unlocking the Battery: step 1, image 1 of 1
      • Slide the left and the right battery release latches to the unlock position.
      Ask FixBot
    2. Dell Vostro 3450 Memory Module Replacement, Removing the Battery: step 2, image 1 of 1
      • Slide the battery and remove it from the computer.
      Ask FixBot
    1. Dell Vostro 3450 Memory Module Replacement, Loosen the Screw: step 3, image 1 of 1
      • Loosen the screw that secures the memory door.
      Ask FixBot
    2. Dell Vostro 3450 Memory Module Replacement, Removing the Memory Door: step 4, image 1 of 1
      • Pry up the memory door near the screw hole, lift and remove it.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
    1. Dell Vostro 3450 Memory Module Replacement, Popping up the Memory Module: step 5, image 1 of 1
      • Pry the retention clips away from the memory module until it pops up.
      Ask FixBot
    2. Dell Vostro 3450 Memory Module Replacement, Remove the Memory Module: step 6, image 1 of 1
      • Remove the memory module from its connector on the system board.
      Ask FixBot
Finish Line
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 59
All Time: 855
