Dell Vostro 3360 Hard Drive Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
81
All Time:
3,850
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: step 1, image 1 of 1
      • Remove the screw that secures the keyboard to the chassis.
      Ask FixBot
    2. Dell Vostro 3360 Hard Drive Replacement, Prying the Keyboard: step 2, image 1 of 1
      • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
      Ask FixBot
    3. Dell Vostro 3360 Hard Drive Replacement, Flipping the Keyboard: step 3, image 1 of 1
      • Flip the keyboard over and lay it on the palmrest.
      Ask FixBot
    4. Dell Vostro 3360 Hard Drive Replacement, Lifting the Clip: step 4, image 1 of 1
      • Lift the clip to release the keyboard cable and disconnect it from the computer.
      Ask FixBot
    1. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: step 5, image 1 of 1
      • Remove the screw that secures the access panel to the computer.
      Ask FixBot
    2. Dell Vostro 3360 Hard Drive Replacement, Remove the Access Panel: step 6, image 1 of 1
      • Remove the access panel from the computer.
      Ask FixBot
    1. Dell Vostro 3360 Hard Drive Replacement, Display-Hinge Cover: step 7, image 1 of 1
      • Remove the screws that secure the display-hinge cover to the computer
      Ask FixBot
    2. Dell Vostro 3360 Hard Drive Replacement, Remove the Display Hinge Cover: step 8, image 1 of 1
      • Remove the display-hinge cover from the computer.
      Ask FixBot
    1. Dell Vostro 3360 Hard Drive Replacement, Prying the Rubber Pads: step 9, image 1 of 1
      • Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
      Ask FixBot
    2. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: step 10, image 1 of 1
      • Remove the screws that secure the palm-rest to the computer.
      Ask FixBot
    3. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the Board Cable: step 11, image 1 of 1
      • Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
      Ask FixBot
    4. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the LED Cable: step 12, image 1 of 1
      • Disconnect the power LED cable and the LED board cable from the system board.
      Ask FixBot
    5. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: step 13, image 1 of 1
      • Remove the screws that secure the palmrest to the front of the computer.
      Ask FixBot
    6. Dell Vostro 3360 Hard Drive Replacement, Prying the Edges of the Palm-Rest: step 14, image 1 of 1
      • Pry along the edges of the palmrest to release the palmrest.
      Ask FixBot
    7. Dell Vostro 3360 Hard Drive Replacement, Lifting the Palm Rest: step 15, image 1 of 1
      • Lift the palm-rest up and away from the computer.
      Ask FixBot
    1. Dell Vostro 3360 Hard Drive Replacement, Hard Drive: step 16, image 1 of 1
      • Remove the screws that secure the hard drive to the computer.
      Ask FixBot
    2. Dell Vostro 3360 Hard Drive Replacement: step 17, image 1 of 1
      • Lift the hard drive to disconnect the hard-drive cable
      Ask FixBot
    3. Dell Vostro 3360 Hard Drive Replacement: step 18, image 1 of 1
      • Disconnect the hard-drive cable from the hard drive and remove the hard drive from the computer
      Ask FixBot
    4. Dell Vostro 3360 Hard Drive Replacement: step 19, image 1 of 1
      • Remove the screws that secure the hard-drive bracket to the hard drive and remove the hard drive bracket from it.
      Ask FixBot
4 other people completed this guide.
Johnathan Hammond
46,347 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 81
All Time: 3,850
