Up to 20% off select tools
Dell Vostro 2510 Memory Module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
53
All Time:
431
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 6 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will show you how to remove and replace the Memory Module.
    1. Dell Vostro 2510 Memory Module Replacement, Removing the Battery: step 1, image 1 of 1
      • Slide the battery lock to the open position.
      • Slide the battery release latch to the open position.
      • Slide the battery out of the battery bay.
      Ask FixBot
    1. Dell Vostro 2510 Memory Module Replacement, Remove the Screws: step 2, image 1 of 1
      • Remove the two screws that secure the memory cover, then remove the cover and set it aside.
      Ask FixBot
    2. Dell Vostro 2510 Memory Module Replacement, Removing the Memory Module: step 3, image 1 of 1
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
      • Remove the memory module from the connector.
      Ask FixBot
Finish Line
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 53
All Time: 431
