Up to 20% off select tools
Dell Vostro 1710 RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
61
All Time:
935
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
RAM is needed for a computer to function. If your computer is crashing you may have old or damaged RAM. It can be damaged by static electricity and if it is not removed or inserted correctly. Adding more RAM to your computer can improve its performance drastically.
    1. Dell Vostro 1710 RAM Replacement, Battery: step 1, image 1 of 2 Dell Vostro 1710 RAM Replacement, Battery: step 1, image 2 of 2
      • Make certain that the power to your laptop is off.
      • Press and slide the two buttons outwards and away from the battery.
      Ask FixBot
    2. Dell Vostro 1710 RAM Replacement: step 2, image 1 of 1
      • Slide the battery away and parallel from the laptop.
      Ask FixBot
    3. Dell Vostro 1710 RAM Replacement: step 3, image 1 of 1
      • Remove the battery from the slot.
      Ask FixBot
    1. Dell Vostro 1710 RAM Replacement, Back Panel: step 4, image 1 of 2 Dell Vostro 1710 RAM Replacement, Back Panel: step 4, image 2 of 2
      • Unscrew the eight 6mm screws with a Philips #1 screw driver.
      Ask FixBot
    2. Dell Vostro 1710 RAM Replacement: step 5, image 1 of 1
      • Lift back cover from the groove on the left side of the cover next to the symbol.
      Ask FixBot
    1. Dell Vostro 1710 RAM Replacement, RAM: step 6, image 1 of 2 Dell Vostro 1710 RAM Replacement, RAM: step 6, image 2 of 2
      • Push the metal tabs outward and away from the RAM.
      Ask FixBot
    2. Dell Vostro 1710 RAM Replacement: step 7, image 1 of 2 Dell Vostro 1710 RAM Replacement: step 7, image 2 of 2
      • Pull the top piece straight out of the socket.
      Ask FixBot
    3. Dell Vostro 1710 RAM Replacement: step 8, image 1 of 2 Dell Vostro 1710 RAM Replacement: step 8, image 2 of 2
      • Repeat the same process by pushing the bottom metal tabs outward and away from the RAM.
      Ask FixBot
    4. Dell Vostro 1710 RAM Replacement: step 9, image 1 of 2 Dell Vostro 1710 RAM Replacement: step 9, image 2 of 2
      • Pull the bottom piece straight out of the socket.
      Ask FixBot
Author
with
Sarah Dulac
270 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 61
All Time: 935
