Dell Vostro 1710 Keyboard Replacement
    1. Dell Vostro 1710 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Vostro 1710 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Make certain that the power to your laptop is off.
      • Press and slide the two buttons outwards and away from the battery.
      Ask FixBot
    2. Dell Vostro 1710 Keyboard Replacement: step 2, image 1 of 1
      • Slide the battery away and parallel from the laptop.
      Ask FixBot
    3. Dell Vostro 1710 Keyboard Replacement: step 3, image 1 of 1
      • Remove the battery from the slot.
      Ask FixBot
    1. Dell Vostro 1710 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Dell Vostro 1710 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Dell Vostro 1710 Keyboard Replacement, Keyboard: step 4, image 3 of 3
      • Use the plastic opening tool to loosen the plastic hinge cover that is located above the keyboard.
      Ask FixBot
    2. Dell Vostro 1710 Keyboard Replacement: step 5, image 1 of 2 Dell Vostro 1710 Keyboard Replacement: step 5, image 2 of 2
      • Remove plastic hinge cover by gently lifting up the cover with a plastic opening tool from one side to the other.
      Ask FixBot
    3. Dell Vostro 1710 Keyboard Replacement: step 6, image 1 of 2 Dell Vostro 1710 Keyboard Replacement: step 6, image 2 of 2
      • Remove the four 3mm Philips #1 head screws.
      Ask FixBot
    4. Dell Vostro 1710 Keyboard Replacement: step 7, image 1 of 2 Dell Vostro 1710 Keyboard Replacement: step 7, image 2 of 2
      • Gently lift up the keyboard to remove.
      • Flip it over as it shown in the picture.
      Ask FixBot
    5. Dell Vostro 1710 Keyboard Replacement: step 8, image 1 of 2 Dell Vostro 1710 Keyboard Replacement: step 8, image 2 of 2
      • Lift the black tab that the keyboard is plugged into.
      Ask FixBot
    6. Dell Vostro 1710 Keyboard Replacement: step 9, image 1 of 2 Dell Vostro 1710 Keyboard Replacement: step 9, image 2 of 2
      • Pull directly outwards to remove the keyboard completely.
      Ask FixBot
Tangxiao Sun
496 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 67
All Time: 1,118
