Dell Vostro 1710 Fan Replacement
    1. Dell Vostro 1710 Fan Replacement, Battery: step 1, image 1 of 2 Dell Vostro 1710 Fan Replacement, Battery: step 1, image 2 of 2
      • Make certain that the power to your laptop is off.
      • Press and slide the two buttons outwards and away from the battery.
      Ask FixBot
    2. Dell Vostro 1710 Fan Replacement: step 2, image 1 of 1
      • Slide the battery away and parallel from the laptop.
      Ask FixBot
    3. Dell Vostro 1710 Fan Replacement: step 3, image 1 of 1
      • Remove the battery from the slot.
      Ask FixBot
    1. Dell Vostro 1710 Fan Replacement, Back Panel: step 4, image 1 of 2 Dell Vostro 1710 Fan Replacement, Back Panel: step 4, image 2 of 2
      • Unscrew the eight 6mm screws with a Philips #1 screw driver.
      Ask FixBot
    2. Dell Vostro 1710 Fan Replacement: step 5, image 1 of 1
      • Lift back cover from the groove on the left side of the cover next to the symbol.
      Ask FixBot
    1. Dell Vostro 1710 Fan Replacement, Fan: step 6, image 1 of 2 Dell Vostro 1710 Fan Replacement, Fan: step 6, image 2 of 2
      • Unclip the power supply by pulling the cable directly up and out of the socket.
      Ask FixBot
    2. Dell Vostro 1710 Fan Replacement: step 7, image 1 of 2 Dell Vostro 1710 Fan Replacement: step 7, image 2 of 2
      • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
      Ask FixBot
    3. Dell Vostro 1710 Fan Replacement: step 8, image 1 of 2 Dell Vostro 1710 Fan Replacement: step 8, image 2 of 2
      • Gently lift and pull to the left until the fan is free from the heatsink.
      Ask FixBot
Tangxiao Sun
496 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 63
All Time: 739
