Up to 20% off select tools
Dell Vostro 1700 Memory Module Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
57
All Time:
699
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Module.
    1. Dell Vostro 1700 Memory Module Replacement, Removing the Battery: step 1, image 1 of 1
      • Slide and click the battery release latches to keep them open.
      • Slide the battery out of the bay.
      Ask FixBot
    1. Dell Vostro 1700 Memory Module Replacement, Removing the Hinge Cover: step 2, image 1 of 1
      • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
      • Ease the hinge cover up, moving from right to left, and remove it.
      Ask FixBot
    1. Dell Vostro 1700 Memory Module Replacement, Removing the Keyboard: step 3, image 1 of 1
      • Remove the four screws at the top of the keyboard.
      • NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and timeconsuming to replace. Be careful when removing and handling the keyboard.
      • Slide the keyboard toward the back of the computer to disengage the notch on the keyboard from the tab on the base of the computer.
      • Lift and remove the keyboard.
      Ask FixBot
    1. Dell Vostro 1700 Memory Module Replacement, Removing the Memory Module: step 4, image 1 of 1
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      • Remove the memory module from the connector.
      Ask FixBot
Finish Line
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 57
All Time: 699
