Dell Vostro 1500 Keyboard Replacement
    1. Dell Vostro 1500 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Make certain the power is off.
      Ask FixBot
    2. Dell Vostro 1500 Keyboard Replacement: step 2, image 1 of 1
      • Press and slide the buttons inward.
      Ask FixBot
    3. Dell Vostro 1500 Keyboard Replacement: step 3, image 1 of 1
      • Slide the battery away from the computer.
      Ask FixBot
    4. Dell Vostro 1500 Keyboard Replacement: step 4, image 1 of 1
      • Remove the battery from the slot.
      Ask FixBot
    1. Dell Vostro 1500 Keyboard Replacement, Keyboard: step 5, image 1 of 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: step 5, image 2 of 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: step 5, image 3 of 3
      • Pry the top panel up from the tab in the upper right hand corner.
      • Run your finger under the panel from right to left to pop it loose.
      • You might have to tilt back the screen if you are having trouble popping it loose.
      Ask FixBot
    2. Dell Vostro 1500 Keyboard Replacement: step 6, image 1 of 2 Dell Vostro 1500 Keyboard Replacement: step 6, image 2 of 2
      • Unscrew the two Phillips head screws.
      Ask FixBot
    3. Dell Vostro 1500 Keyboard Replacement: step 7, image 1 of 2 Dell Vostro 1500 Keyboard Replacement: step 7, image 2 of 2
      • Carefully lift the keyboard away from the computer.
      • Pull the keyboard toward the screen.
      • Do not pull too hard on the keyboard as the connector could be damaged.
      Ask FixBot
    4. Dell Vostro 1500 Keyboard Replacement: step 8, image 1 of 3 Dell Vostro 1500 Keyboard Replacement: step 8, image 2 of 3 Dell Vostro 1500 Keyboard Replacement: step 8, image 3 of 3
      • Lift the blue plastic cover so that is at a 90 degree angle to the keyboard to remove the connection to the keyboard.
      Ask FixBot
    5. Dell Vostro 1500 Keyboard Replacement: step 9, image 1 of 1
      • Pull the connector toward the screen.
      Ask FixBot
2 other people completed this guide.
Daniel Roskuski
219 Reputation
2 Guides authored
UMass Dartmouth, Team 1-3, Catania Fall 2016 Member of UMass Dartmouth, Team 1-3, Catania Fall 2016
UMASSD-CATANIA-F16S1G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 110
All Time: 1,373
