Dell Vostro 15 KeyBoard Replacement
    1. Dell Vostro 15 KeyBoard Replacement, Battery: step 1, image 1 of 1
      • Slide the battery release latches until they click into place.
      • Slide the battery out of the battery bay.
      Ask FixBot
    1. Dell Vostro 15 KeyBoard Replacement, Hinge Cover: step 2, image 1 of 1
      • Open the display all the way so that it rests flat on your work surface.
      • NOTICE: To avoid damage to the hinge cover, do not lift the cover on both sides simultaneously.
      • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
      • Moving from right to left, ease the hinge cover up, then remove it and set it aside.
      Ask FixBot
    1. Dell Vostro 15 KeyBoard Replacement, KeyBoard: step 3, image 1 of 1
      • Remove the two M2.5 x 5-mm screws at the top of the keyboard.
      • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
      • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
      • Rotate the keyboard connector latch upward to release the keyboard cable.
      • Slide the keyboard cable out of the keyboard connector.
      Ask FixBot
Johnathan Hammond
46,320 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 93
All Time: 1,087
