Up to 20% off select tools
Dell Vostro 15 3568 Memory Module Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
67
All Time:
2,508
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. Dell Vostro 15 3568 Memory Module Replacement, Battery: step 1, image 1 of 1
      • Slide the release latch to release the battery [1].
      • Remove the battery from the computer [2].
      Ask FixBot
    1. Dell Vostro 15 3568 Memory Module Replacement, KeyBoard: step 2, image 1 of 1
      • Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
      • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
      Ask FixBot
    2. Dell Vostro 15 3568 Memory Module Replacement: step 3, image 1 of 1
      • Disconnect the keyboard cable from the system board.
      • Lift the keyboard cable to remove it from the computer.
      Ask FixBot
    1. Dell Vostro 15 3568 Memory Module Replacement, Base Cover: step 4, image 1 of 1
      • Disconnect the optical drive connector and lift it to remove it from the system board [1].
      • Remove the screws inside the palmrest [2].
      Ask FixBot
    2. Dell Vostro 15 3568 Memory Module Replacement: step 5, image 1 of 1
      • Remove the screws that secure the base cover to the computer
      Ask FixBot
    3. Dell Vostro 15 3568 Memory Module Replacement: step 6, image 1 of 1
      • Pry the edges of the base cover [1].
      • Lift the base cover and remove it from the computer [2].
      Ask FixBot
    1. Dell Vostro 15 3568 Memory Module Replacement, Memory Module: step 7, image 1 of 1
      • Pull the clips securing the memory module until the memory module pops up [1].
      • Remove the memory module from the system board [2].
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 67
All Time: 2,508
