Up to 20% off select tools
Dell Vostro 15 3565 Memory Module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
51
All Time:
522
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Dell Vostro 15 3565 Memory Module Replacement, Battery: step 1, image 1 of 1
      • Slide the release latch to unlock the battery [1].
      • Remove the battery from the computer [2].
      Ask FixBot
    1. Dell Vostro 15 3565 Memory Module Replacement, Optical-Disk Drive: step 2, image 1 of 1
      • Remove the screw that secures the optical drive to the computer [1].
      • Using a plastic scribe push the tab to release the optical drive [2].
      • Slide the optical drive out of the computer [3].
      Ask FixBot
    1. Dell Vostro 15 3565 Memory Module Replacement, KeyBoard: step 3, image 1 of 1
      • Release the keyboard by prying on the keyboard release tabs by using a scribe.
      Ask FixBot
    2. Dell Vostro 15 3565 Memory Module Replacement: step 4, image 1 of 1
      • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
      Ask FixBot
    3. Dell Vostro 15 3565 Memory Module Replacement: step 5, image 1 of 1
      • Disconnect the keyboard cable from the system board [1].
      • Lift the keyboard cable to remove it from the computer [2].
      Ask FixBot
    1. Dell Vostro 15 3565 Memory Module Replacement, Base Cover: step 6, image 1 of 1
      • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
      • Remove the screws inside the palmrest [3].
      Ask FixBot
    2. Dell Vostro 15 3565 Memory Module Replacement: step 7, image 1 of 1
      • Remove the screws that secure the base cover to the computer [1].
      • Pry the edges of base cover and lift it to remove it from computer [2].
      Ask FixBot
    1. Dell Vostro 15 3565 Memory Module Replacement, Memory Module: step 8, image 1 of 1
      • Pull the clips securing the memory module until the memory module pops up [1].
      • Remove the memory module from the system board [2].
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 51
All Time: 522
