Up to 20% off select tools
Dell Vostro 15 3562 Memory Module Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
12
Past 30 Days:
55
All Time:
650
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Dell Vostro 15 3562 Memory Module Replacement, Battery: step 1, image 1 of 1
      • Slide the release latch to release the battery [1].
      • Remove the battery from the computer [2].
      Ask FixBot
    1. Dell Vostro 15 3562 Memory Module Replacement, Optical-Disk Drive: step 2, image 1 of 1
      • Remove the M2L3 screw that secures the optical drive to the computer [1].
      • Using a plastic scribe, push the tab in the direction of the arrow indicated on the chassis. [2].
      • Slide the optical drive out of the computer [3].
      Ask FixBot
    1. Dell Vostro 15 3562 Memory Module Replacement, KeyBoard: step 3, image 1 of 1
      • Using a plastic scribe, release the five tabs from the slots located above the keyboard [1].
      • Flip the keyboard on the palm rest to access the keyboard connector cable under the keyboard [2].
      Ask FixBot
    2. Dell Vostro 15 3562 Memory Module Replacement: step 4, image 1 of 1
      • Disconnect the keyboard cable from the system board.
      • Remove the keyboard from the computer.
      Ask FixBot
    1. Dell Vostro 15 3562 Memory Module Replacement, Base Cover: step 5, image 1 of 1
      • Disconnect the optical drive connector and lift it to remove it from the system board [1].
      • Remove the M2L5 screws that secure the base cover [2].
      Ask FixBot
    2. Dell Vostro 15 3562 Memory Module Replacement: step 6, image 1 of 1
      • Flip the computer and remove the screws (8 screws - M2.5L8; 3 screws - M2L2; 2 screws- M2L2) that secure the base cover to the computer.
      Ask FixBot
    3. Dell Vostro 15 3562 Memory Module Replacement: step 7, image 1 of 1
      • Use a scribe to pry the edges of the base cover [1].
      • Lift the base cover and remove it from the computer [2].
      Ask FixBot
    1. Dell Vostro 15 3562 Memory Module Replacement, Memory Module: step 8, image 1 of 1
      • Pull the clips securing the memory module until the memory module pops up [1].
      • Remove the memory module from the system board [2].
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 55
All Time: 650
